Old 04-28-2010, 10:05 PM   #1
Exterior Painting Questions (mainly re: gutters)
I have white leaf guard gutters in good condition installed, and I am wondering what I do about them when I paint my house this summer.
Can I paint them the same color as my trim? If so, how do I go about painting them (same paint?). If I go with a maroon trim, will the color turn out okay? I was planning on first spraying a primer that was recommended for my t-111 siding, then spraying the house color, then going over the trim pieces with a brush/roller in the trim color I choose.
See, my original plan was to go with a white trim, so I would just cover the gutters and paint around them, but now I'm considering a different color trim.
Also, my cement foundation currently has some over-spray from the last paint job. Should I just paint that the new color so it all blends in, or should I stay away from painting the cement?
Thanks.
jayare is offline   Reply With Quote
Old 04-29-2010, 02:37 AM   #2
I would not paint the gutters. Right now they are maintenance free. Once they are painted you must maintain them. Besides, white will go with whatever trim color you choose.
I always paint the foundation or parging.
Windows is offline   Reply With Quote
Old 04-29-2010, 11:20 PM   #3
Thanks for the reply. I was thinking it might look funny having different color trim and gutters. I'll try to find some pictures of houses with a set up like that.
Old 04-30-2010, 11:07 AM   #4
Matthewt1970's Avatar
Also gutters will typicly have a baked on glossy finish. Very tough to get paint to stick to it.
Icicles build up from leaf guard gutters tn312c Roofing/Siding 25 01-06-2011 03:22 PM
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 09:25 PM
cutting shingles to install gutters Chicago Bill General Discussion 2 02-27-2009 06:42 AM
Box Gutters Fix or Aluminum? jonathan03 Roofing/Siding 4 01-01-2009 01:42 PM
Do I replace my gutters? nymark Roofing/Siding 5 06-18-2008 10:36 PM
