Exterior Paint For Wood Trim - Painting - DIY Chatroom Home Improvement Forum
Old 11-28-2013, 04:55 PM   #1
Rewards Points: 2,166
exterior paint for wood trim
I'm no where near ready to think about painting exterior trim. But, in order to put new weatherstripping up I need to paint the wood trim around a door.
S.W. said to use 'Resilience'. Is that the best choice, in the opinion of those here?
The old paint looks good, I just want a different color, but I suppose I have to sand it a little?
thanks
Startingover is offline   Reply With Quote
Old 11-28-2013, 07:35 PM   #2
Rewards Points: 13,712
Got a picture of this trim?
Why not just remove and replace with PVC and never have to worry about it again.
Startingover (11-28-2013)
Old 11-28-2013, 08:17 PM   #3
Gymschu's Avatar
Rewards Points: 832
Maybe a light sanding, clean, topcoat with SW's Superpaint.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 11-28-2013, 08:33 PM   #4
Rewards Points: 5,974
Or SW ASE(all surface enamel). All the paint co. have good choices for ext. trim. I personally have not had good results with box store paint. Looked good when applied but really seemed to dull quickly.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 11-28-2013, 08:59 PM   #5
The reviews on it look pretty bad.
http://www.sherwin-williams.com/home...rringCategory=
Old 11-28-2013, 09:35 PM   #6
ltd
Rewards Points: 536
nothing wrong with resilience ,its good paint. superpaint or duration is better imho . mabey you only needed a qt. and in a lot of s/w stores resilience is all they have in qts.
ltd is offline   Reply With Quote
The Following User Says Thank You to ltd For This Useful Post:
Old 11-28-2013, 10:40 PM   #7
will post a photo tomorrow. (see below)
Joe, I wouldn't be capable of replacing the trim.
Yes, a quart is all I need for now.
The guy who used to wait on me at S.W. and who I liked the best, took a sales rep job and is no longer there, so I appreciate the advice.
Someone here, 1.5 yrs ago, when I bought this house, recommended Super Paint and I painted the entire house with it and have been very pleased. I just didn't know you could use it outside. But I'm going to use Duration.
Old 11-29-2013, 09:13 AM   #8
Old 11-29-2013, 09:22 AM   #9
Gymschu's Avatar
Rewards Points: 832
SO, yes, SW makes an interior version and an exterior version of SuperPaint. The ext. version comes in a gold colored can, the int. version in a blue colored can. Make sure you tell them exterior!
And, finally, you may just want to buy a gallon as it is about the same price as a quart.
Oops, skip all of that, I see you are getting Duration!
Startingover (11-29-2013)
Old 11-29-2013, 09:23 AM   #10
If that door gets direct sun it never should have been painted that dark color.
It's going to fade, act like a heat sink and transfer the heat to the inside of the house and can do damage to the door.
Old 11-29-2013, 09:48 AM   #11
It's an East door. The double garage overhead door was the same dark brown and turned very chalky orange from the south sun.
I was going with S.W.'s "Tower Tan" sample on the door, but think I want it slightly darker.
Gymschu: I won't have time to start on the overhead garage door till next spring, so should I still buy a gallon?
Old 11-29-2013, 10:56 AM   #12
Yes buy the gallon when finished seal tight and will be good in the spring. Keep it somewhere so it won't freeze.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
Gymschu (11-29-2013), Startingover (11-29-2013)
Trim that is covered by flooring bmbigda Carpentry 12 11-07-2013 02:32 PM
Door & Window Trim / Casing Overhaul - Craftsman Style lohryx5 Remodeling 7 07-11-2013 07:52 AM
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 10:29 PM
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 12:21 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
