Exterior Paint Stripping - Painting - DIY Chatroom Home Improvement Forum
Old 03-24-2009, 06:10 AM   #1
exterior paint stripping
Hello
I own an older home that has redwood siding. the siding is in great shape except the paint is peeling. Has anyone used the Smart Srtip pull and strip products from Dumond? If so how were the results? This product is some what costly are there other products just as good but less expensive? Thanks for any help.
wiilhay is offline   Reply With Quote
Old 03-24-2009, 07:46 AM   #2
Remodeling Contractor
Exterior stripping is done with sanders. They make a great disk sander that is made specifically for paint removal on siding.
Old 03-24-2009, 08:22 AM   #3
Stripping
Bob,
Thanks for the info, I'll check it out.
Old 03-24-2009, 08:55 AM   #4
the Musigician
DangerMouse's Avatar
if you have 12 layers of paint....... you'll go through a LOT of paper!
http://www.usfreeads.com/610840-cls.html
i say go for it, you'll likely save yourself a LOT of elbow grease.
"Smart Strip is most notable for being safer for the user, the substrate and the environment. It is classified as non-hazardous, is pH neutral, and does not contain methylene chloride, caustics, VOCs or NMP. It is a water-based product and is 100% biodegradable. It is extremely effective at removing multiple layers of architectural and tough industrial coatings from virtually all exterior and interior surfaces of wood, brick, metal, concrete, stone, plaster, fiberglass, etc."
DM
Old 03-24-2009, 09:01 AM   #5
DM
This does not use any paper, it is more like a planner blade with the plate and guides made for siding paint removal.
Old 03-24-2009, 09:18 AM   #6
the Musigician
it may help the OP and others if you posted a link to the tools? all i imagined was the big mess either way! lol
"older" home says to me, many, many possible layers of paint.
DM
Old 03-24-2009, 09:30 AM   #7
DM
These are also available for sanding with vacuum hoses. Not mess..
http://www.paintshaver.com/
Old 03-24-2009, 09:38 AM   #8
the Musigician
see? that wasn't so hard now was it? hehehehe
tnkx for the pic. a vacuum would certainly make a difference.
DM
Old 03-24-2009, 11:16 AM   #9
yes, I use a backpack model (swinger) and this saves so much with the impossible task of cleaning paint chips out of bushes and mulch. It will take all layers off at one time, just adjust the setting. Some sanding touch-up is needed to remove swirls if you are not using it in balance.
Old 03-24-2009, 11:39 AM   #10
Matthewt1970's Avatar
Rewards Points: 1,098
We used to use the chemical strippers, but they are NOT recommended for the DIY'er. It can eat holes in your skin. Nasty stuff.
Old 03-24-2009, 01:25 PM   #11
Thanks guys, for the feedback. Looks like sanding is the way to go.
Old 03-25-2009, 10:50 AM   #12
Rewards Points: 150
Man, I wish I had known about that paint shaver contraption when I started painting my house. I am only half finished and am tempted to buy it. I have some peeling paint on the side and back but its not to terrible. That would have saved me weeks on the front of the house though.
At one point does stripping become manditory?
Evan
240sx4u is offline   Reply With Quote
Old 03-25-2009, 12:35 PM   #13
if someone used the wrong paint. Normally all you need to do is remove loose chips and sand to feather the edges. Priming is only needed for bare or patched areas.
Old 03-25-2009, 12:37 PM   #14
Rewards Points: 150
Alright cool, then I won't fret. It sounds like I did it right. You can see where the paint was peeling but thats is only if your looking for it.
Thanks for the reassurance.
Evan
Old 03-25-2009, 12:38 PM   #15
It is never really maditory, but I would say when the surface is around 40% failed paint it only makes sence to just strip it all off.
replacing weather stripping on front door cao911 Remodeling 5 09-07-2012 05:29 PM
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 11:58 PM
Best paint remover for stripping latex? DanielP Painting 3 04-30-2008 08:21 AM
stripping paint from brick jane@creativemattersinc.c Remodeling 1 11-15-2007 10:36 PM
