Exterior Paint Removal - Lead - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-24-2014, 08:01 PM   #16
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
A true hepa vac that's epa lead approved will run you about $600.00 and up wards. The paint shaver is great, but remember you still have to usually sand the clapboards using a random orbit sander after using the paint shaver.
When we completely strip all of the paint off of a building we prefer to use chemical stripping. Chemical stripping will remove all of the paint if you use the proper products. Either way you go it's time consuming and a labor intensive process to remove all of the paint from a building. Peel Away has several lines of paint strippers that work pretty well.
housepaintingny is offline   Reply With Quote
The Following 2 Users Say Thank You to housepaintingny For This Useful Post:
Gymschu (04-25-2014), ToolSeeker (04-25-2014)
Old 04-26-2014, 08:29 PM   #17
Yeah I'll have to sand it afterwards too. I already have a true hepa vac that meets EPA regulations. It was obnoxiously expensive for a vacuum.
I'm also restoring all of our windows, 30 double hung and 6 picture windows - so I'll be dealing with lead paint for a while. It'll be nice in a couple years when at least all the exterior lead paint is gone.
PaintChips is offline   Reply With Quote
Old 04-28-2014, 07:12 PM   #18
Unhappy
Don't burn the house down
The danger in using any form of heat gun to remove paint is that it may start wood dust (or paper, or anything flammable) on the inside of the wall smouldering, which will burst into flame after you've packed up and left the job for the day. The "infrared" paint remover site says it heats the paint to 400 degrees F; paper ignites at 454 degrees. "Infrared" is just heat, by the way.
Sanding the entire surface of a 3000 sq. ft. house is something to avoid. It would be easier, cheaper, and faster to put on entirely new clapboards. You would also see exactly what was beneath them and maybe needs fixing, and you would replace all the flashing and do it right for once and all. Paint the bottom narrow side of the clapboards a different color (while in a stack at ground level) so it will look like insanely detailed pinstriping when put up.
Ed Ferris is offline   Reply With Quote
Old 05-13-2014, 04:21 PM   #19
I haven't looked into the prices on clapboard - but I doubt from a DIY perspective that it would be cheaper. It is tempting so I'll do the math on it when I get closer to the project :-D
Old 05-13-2014, 04:24 PM   #20
Jmayspaint's Avatar
Rewards Points: 534
If you take a look over at Paint Talk one of the current threads called "Starting this Wednesday" is about a painting company doing a full RRP removal using the paint shaver ad infrared heat stripper. They don't like DIY's posting over there but you might get some insight on how it goes from the thread.
Jmayspaint is online now   Reply With Quote
Old 05-13-2014, 04:36 PM   #21
Just from a quick glance it looks like it would take at least $1k in peel away to strip this house - if not more.
Old 05-13-2014, 04:48 PM   #22
JMays - do you have a link for it?
Old 05-13-2014, 05:05 PM   #23
Jmayspaint's Avatar
Rewards Points: 534
This might work
http://www.painttalk.com/f2/starting-wednesday-27955/
The Following User Says Thank You to Jmayspaint For This Useful Post:
PaintChips (05-13-2014)
Old 05-13-2014, 06:00 PM   #24
Thanks!
Old 05-13-2014, 08:01 PM   #25
Rewards Points: 5,974
The trouble with the infared heaters is they are incredibly slow. And really $1000 for stripper would not be bad. When you compare it with $15,000 to have it done.
Tags
lead , removal
Removal and disposal of lead shower pan gbook2 Plumbing 6 03-18-2012 10:33 AM
Wallpaper removal and lead paint risk? rhena Painting 12 06-07-2011 05:30 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Wood Siding Removal with Lead mrvt Building & Construction 3 01-16-2011 06:07 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
