Exterior Paint Recommendations - Painting - DIY Chatroom Home Improvement Forum
Old 10-01-2008, 05:44 PM   #1
Exterior Paint recommendations
I am getting ready to repaint our house. The house is sided w/ Hardiplank and is about 6 years old. The builder used Frazee paint based on ICI colors. Does Frazee make good paint or is ICI better? Is there another brand that I should consider? I've seen other posts recommending Ben Moore and Sherwin Williams?
Thanks.
staylor34 is offline   Reply With Quote
Old 10-01-2008, 06:09 PM   #2
the Musigician
DangerMouse's Avatar
if you can afford it, SW seems to be the hands down winner around here.
DM
Old 10-01-2008, 07:15 PM   #3
Rewards Points: 506
Really, the top, or near top, paint from any actual paint store (i.e. NOT a Big Box store) will work. ICI makes fine paints, as does Sherwin or Ben Moore, Pratt & Lambert, Porter, etc.
Frazee is one of those small regional brands that possibly does have the advantage of making products customized for the climates common in their market area, instead of having to make products that try to work everywhere.
sirwired is offline   Reply With Quote
Old 10-02-2008, 02:11 AM   #4
Thanks MdangermouseM and sirwired. I appreciate the input.
Old 10-08-2008, 07:02 AM   #5
Question
6 years?
Our new townehouse complex has hardiboard siding and we are planning to build a reserve fund to paint it in the future. Our contractor set an 8-yr life expectancy on the siding paint. Are you painting to change colors, or do we need to consider lowering our life expectancy?
Bill
BADGER BILL is offline   Reply With Quote
Old 10-08-2008, 09:46 AM   #6
Rewards Points: 506
Whether or not you need to consider lowering your life expectancy wholly depends on the quality of the prep and product for the existing coat. 8-yrs is fairly reasonable, assuming a quality existing job. It could be more or less, depending on prep, product, and climate.
SirWired
Old 10-08-2008, 05:36 PM   #7
exterior paint
Not sure if you're also debating paint colors, which I know can be exhausting! Here's some advice from the Paint Quality Institute about how to select exterior paint colors. Cool pictures, too.
http://www.oldhouseweb.com/architect...-schemes.shtml
Allison1888 is offline   Reply With Quote
Recommendations for best DIY books to buy? Beth777 General DIY Discussions 4 10-02-2008 10:07 AM
Recommendations on Front Loaders Washer/ Dryer helpless handyman Appliances 6 02-15-2008 11:59 AM
Airless paint sprayer recommendations helpless handyman Painting 7 10-09-2007 05:39 PM
Respirator recommendations? carrie brooklyn General DIY Discussions 2 06-04-2006 10:54 PM
