Old 07-27-2010, 11:02 PM   #1
Send a message via ICQ to farmerjack
exterior paint prep
How much is enough?
I'm preping a 60s house with cove lap siding. In scraping, I am finding that, when scraping a damaged area, on some boards, I can peel off the old latex paint well past any visable damage. It comes off like a sheet of paper with a putty knife all the way down to bear wood.
My question is, if it comes off that easily, should it be removed till I reach a point where it is still holding on, or am I wasting my time removing paint that could be painted over satisfactorily?
farmerjack is offline   Reply With Quote
Old 07-28-2010, 06:01 AM   #2
exterior paint prep
Keep up with the prep. Prep is 87% of painting.
mark942 is offline   Reply With Quote
Old 07-28-2010, 12:39 PM   #3
exterior paint prep
Scrape, sand and strip until you feel your arms are going to fall off. Now keep on scraping, sanding, stripping until you get to a good/solid substrate.
Then use the best long oil primer money can buy. Ask the paint store to tint the primer to half the color formula of the topcoat to give you a head start on coverage. (or as much tinting as the primer's manufacturer recommends)
Good prep. will maximize the time when you have to repeat this miserable process.
hennyh is offline   Reply With Quote
Old 07-29-2010, 05:42 AM   #4
paper hanger and painter
chrisn's Avatar
exterior paint prep
It sounds like maybe moisture is a problem also. Besides all the previous good advise,I might look into this site. I have used these with good results( my own home included)
http://www.wedgevent.com/
Old 07-29-2010, 09:18 AM   #5
exterior paint prep
I would start with pressure washing. Pressure washing is the best method for removing old caulk and flaking paint. A clean surface is a crucial step that needs to be done at the beginning.
The next step is scraping and sanding. The scraping and sanding should be done at the same time as each step can find loose paint that the power washer missed. I either use a palm sander which makes life much easier but for those hard places you have to do it by hand.
Now if you have rough wood, like rough sawn cedar, your only choice is to roll up your sleeves and use a wire brush. Wire paint stripper attachments for power drills can also be used which you can find at your local paint supply or home center.
Now before you decide on being all gung-ho you have to remember this is the most labor intensive part of exterior painting, but the most important. All of the loose paint must be found and then removed; this forms the foundation for the entire paint job and if you do it right it will last you a long time and if you can get yourself a scaffold instead of a ladder that would make life so much easier.
Oh I almost forgot there are also environmental concerns with any scraping and sanding of the existing finish on your home. If your home was built before 1978 the exterior finish might contain lead based paint. Lead paint safety is a major concern when painting. Many painted or finished surfaces can contain lead and protecting yourself and your family needs to be a first priority. You need to know what to do and not to do. You can buy a lead test kit which is very easy to use to test for lead. If you do find lead then you would have to contact the proper authorities on your situation.
Now that you have done all of the above the other things you need to do are caulking, masking and priming. I can’t stress enough that top quality products are required in the beginning in order for the final look to be its best. After all preparation is finished; choose the best exterior paint and exterior painting techniques for your project.
epson is offline   Reply With Quote
Old 07-29-2010, 06:30 PM   #6
exterior paint prep
As usual, Chrisn hit it right, (actually, how the heck do I know) Sure sounds like a moisture issue, with it, your new paint will peel off as well. One house I've seen had problems with the basement, too damp down there.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 07-29-2010, 07:37 PM   #7
Xtreme DIY'r
exterior paint prep
If you do pressure wash then wait a while until you paint
Presure washing will force water into cracks & everywhere else
Old 07-30-2010, 03:31 AM   #8
chrisn's Avatar
exterior paint prep
Also,NEVER chalk the under neath of the lap siding!
Old 07-30-2010, 06:45 AM   #9
Matthewt1970's Avatar
exterior paint prep
Originally Posted by farmerjack View Post
How much is enough?
That's the idea. If it is stuck to the house, leave it.
How to prep woodwork to bring back detail? RinSF Painting 3 07-10-2010 12:44 PM
Any wood prep product for cracks in deck wood? FrankL Painting 1 06-11-2010 12:20 PM
Prep help for ready seal Titan5 Painting 1 05-26-2009 08:56 PM
Sub-base/footer prep for pavers on canal rkh2619 General Discussion 1 03-08-2009 09:39 PM
Door Prep Questions BigJimmy Building & Construction 5 10-12-2008 04:49 PM
