Exterior Paint Over Caulked Siding Seams - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 02:23 PM   #16
Too Short? Cut it Again!
Looks like the Rainbuster 900 is paintable. See the painting section of the data sheet:
http://www.topindustrial.com/datasheets/900.pdf
Looks like they are recommending a primer coat and then paint so I would use a high bond primer. The data sheet also suggests you may have to clean the caulked beads to remove contaminants if you see paint surface or adhesion problems.
Should tongue and groove siding be caulked? apara Building & Construction 5 08-15-2010 07:07 PM
How Do You Make "V" Seams In Car Siding? Phil in Wisconsin Carpentry 2 12-26-2008 05:51 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
