Exterior Paint Blistering On Wood - Painting - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 07:52 PM   #1
exterior paint blistering on wood
What would cause paint to bubble or blister on exterior facia wood
LarryG11 is offline   Reply With Quote
Old 12-28-2010, 08:03 PM   #2
Rewards Points: 558
One reason is when painting in direct sunlight or on a hot surface this will entrap the vapors as the paint dries too fast. These vapors expand, causing small to medium sized bubbles under the top layer of paint.
Another reason to cause paint bubbles is moisture coming from inside or outside. Unlike the bubbles associated with heat, moisture bubbles penetrate through all layers of paint, into the surface. The moisture becomes trapped, therefore expanding the paint film. Inside moisture is due to leaks from the house, perhaps because of plumbing problems. Outside moisture can come from precipitation. The bubbles may appear within a few hours or may take as long as a few days to pop up.
epson is offline   Reply With Quote
Old 12-29-2010, 04:59 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
There is you're answer
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 01:42 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
