Exterior Paint For A Bathroom - Painting - DIY Chatroom Home Improvement Forum
Old 12-18-2007, 05:27 AM   #1
exterior paint for a bathroom
is it ok to use exterior oil enamel paint for an interior bathroom?
rodeo is offline   Reply With Quote
Old 12-18-2007, 05:48 AM   #2
Guest
Guest
Posts: n/a
No, not in my opinion. Exterior oil depend on UV to cure. It could stay tacky for quite some time if you try to use it inside. It's going to yellow like mad as well.
Old 12-18-2007, 07:18 AM   #3
i painted my bathroom with the exterior paint a year+ ago. Mustard/beige color. So far, it seems fine and it seems to be an exceptionally tough finish
that holds up great to moisture.
Old 12-18-2007, 10:04 AM   #4
Oldguy
Rehabber's Avatar
I agree with Poppameth, Exterior paints are formulated for high UV-- not indoors
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-18-2007, 08:17 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
Not a good idea, no
Formulated for high UV protection and mildew resistance in an open outdoor area
These exterior paints continue to "off-gas" after curing
Aside from the problems you'll have (or the next occupant will have) trying to repaint, it could lead to total failure (and re-rocking as the cure) eventually
Not that it might not hold...it might
But I've seen way to many failures to say there's not a huge chance
It's one of the biggest "it seemed like a good idea at the time" in painting
Right up there with painting over wallpaper and painting bathroom tiles
slickshift is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 05:34 AM
Bathroom remodel - need advice sparky472 Remodeling 12 10-22-2007 04:03 PM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
