Exterior Oil-based Polyurethane Over Exterior Latex Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 01:26 PM   #1
Question
exterior oil-based polyurethane over exterior latex paint?
hello!
I have recently hand painted some signs for a business. They will be outside and exposed to all elements. The paint is an exterior latex, on top of that I used an oil-based exterior polyurethane. I now hear this might be a problem - that the paint might peel. If so, what is the best way to protect these signs from the elements?
thanks!
exitstrategy is offline   Reply With Quote
Old 05-28-2012, 02:11 PM   #2
Rewards Points: 13,748
It's the poly that's going to start peeling first.
Should have use enamel sign paint and no sealer would be needed.
Old 05-28-2012, 02:11 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Who said the paint will peal? What I would think would happen is that the poly will amber and change the color of your lettering, and that when the weather does get to it ( in a year or two-) it will be the varnish that shows it.
If you painted it with exterior paints- you should have left it with them. Easier to touch up.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-28-2012, 02:12 PM   #4
You really only need to post once.
Old 05-29-2012, 03:04 PM   #5
Rewards Points: 394
Exterior latex paint does not need a clear coat, let alone a solvent based brittle finish. The only alkyd products with actual UV resistance are spar varnish, but they are generally used over stained doors or trim, not latex paints.
Will22 is offline   Reply With Quote
Old 05-29-2012, 04:37 PM   #6
Mr. Paint's Avatar
The best way to keep it from the elements is to put it on an easel behind a window.
The net time you do a sign, do not use an oil-based polyurethane or alkyd varnish. Thse are amber and affect the coloring of the sign/letters. They continue to amber with age. I do not recommend clears over quality paint. There are too many problems that can arise requiring stripping and starting anew.
For now, what's done is done; let nature take its course.
Mr. Paint is offline   Reply With Quote
Tags
painted wood signs , polyurethane
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Stud finder and lead based paint? thunderhead Electrical 1 07-24-2011 06:49 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
removing oil based paint off of brick handycanuck Painting 1 06-18-2010 12:14 PM
