Exterior Metal Door - Painting - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 08:32 AM   #1
exterior metal door
ext. metal door has a very smooth finish primer coat . has been painted many times and now the outer paint coat is chipping and not adhereing to primer coAt . what shold be done to stop the chipping of the finish coat of paint ?
TOM MORTATI is offline   Reply With Quote
Old 10-10-2012, 12:14 PM   #2
Too Short? Cut it Again!
What primer and paint did you use? The primer is adhering but not the finish coat correct? How much time elapsed between the primer and finish coat? Did you race the finish coat, for example? Or leave the primer on long enough for it to pick up a surface layer of film before painting?
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 10:27 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
