Old 10-18-2012, 01:39 PM   #1
exterior latex stain
any suggestions on removing exterior latex from my log cabin?
captain crunch is offline   Reply With Quote
Old 10-18-2012, 01:56 PM   #2
sdsester's Avatar
I am assuming someone applied an acrylic solid or semi-solid stain over the logs or something? Ouch. If it was quality stain you have a real task ahead of you.
I guess pray they used cheap box store stuff over non-prepped and oily logs. Hopefully most will come off when you powerwash. An infrared stripper, scraper and brush might get most off but given the rough surface of the logs it will be a challenge to get it all.
If we are just talking about some drips that hit the logs when painting trim or something? Try any of the latex remover products---Oops, GoofOff, KrudKutter---and see how that goes.
sdsester is offline   Reply With Quote
Old 10-18-2012, 04:24 PM   #3
perma-chinck was applied about seven years ago and i was hoping to find a chemical to strip the stain off so it could be refinished.i contacted a company about doing the ends of the house only and they gave me a price of 7,500.00 for both ends about 1200 sq ft. it would be good to find something to spray on and wash off !!
Old 10-18-2012, 08:07 PM   #4
Painting Company, NY
housepaintingny's Avatar
If its a latex stain i would use Peel Away Smart Strip, nylon brush and pressure washer using low pressure. If its an oil base use a sodium hydroxide based stripper and pressure wash using low pressure followed by citralic acid to netralize.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
captain crunch (10-19-2012)
Latex stain on top of Duron Maxwood oil/acrylic stain? farmery Painting 13 03-12-2013 08:55 AM
Fiberglass door, gel stain, and nervous breakdown wit's end Painting 8 10-26-2011 11:10 PM
Removing stain from deck machouinard Painting 20 09-08-2011 10:12 PM
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 02:57 PM
Need advice on removing deck stain mwalt2 Painting 7 07-23-2008 06:51 AM
