Exterior Front Door - Painting - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 12:03 PM   #1
exterior front door
Used exterior high gloss latex paint on entrance door. Can I polyurethane over the paint to protect it?
Beca is offline   Reply With Quote
Old 07-08-2012, 04:10 PM   #2
Gymschu's Avatar
Rewards Points: 1,036
Don't do it!!!!!!!!! Number one, poly will break down from the UV rays of the sun, and #2, if you ever want to repaint the door you will have to strip the poly or at the very least, have to apply a bonding primer before repainting. Trust me, the high gloss will be more than enough to protect that door. On my own house I have used high gloss on both metal entrance doors and they look as good today as they did when the paint was applied 8 years ago.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
ltd (07-08-2012), martinchris (07-10-2012)
Old 07-08-2012, 04:46 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 622
Why in the world would you want too? If quality paint was used then it is protected as much as it needs to be.
Old 07-09-2012, 09:11 AM   #4
door was a pre-primed door. didn't reprime and now if you run a nail along it you see white where the paint was. Don't know what to do. I have 3 coats on it.
Old 07-09-2012, 09:39 AM   #5
How long since it was painted? If its that exterior acrylic paint it takes a while to set up hard. You said it was factory primed, was it a really smooth finish or did it "feel" like primer? May of needed to be sanded it first.
hayman is offline   Reply With Quote
Old 07-09-2012, 04:52 PM   #6
Gymschu's Avatar
Of course we all forgot the million dollar question. Was it box store paint or quality paint from Sherwin_Williams or Benjamin Moore?
Old 07-09-2012, 04:56 PM   #7
chrisn's Avatar
Rewards Points: 622
Well ,duh, stop scratching it with the nail, let the paint cure for 30 days. If you went scratching poly with a nail what do you think would happen?
Unless you ment FINGER nail? Either way let it cure properly, it should be fine, unless you put on the 2nd and 3rd coats on without drying properly
Old 07-10-2012, 02:00 PM   #8
Thanks, I'll wait longer. Used Valspar paint. Waited between coats. It was my fingernail that hit it, accidently, after about 3 days. I didn't realize it might take a month to cure.
Old 07-10-2012, 08:12 PM   #9
I did some recent painting with latex exterior and noticed it was still a bit soft. I painted some buildings with metal siding last year with exterior acrylic latex paint and checked it out today. That stuff is real hard. You can't touch it with a finger nail, it would take a screw driver or something sharp to scratch it down to metal. I suspect being that its painted on metal and not wood or drywall its going to take a lot longer to cure also.
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 09:27 AM
Rotten bottom plate and subfloor around exterior door deraj123 Building & Construction 5 08-13-2010 10:43 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
1950s Bedroom Door Lock DeeJaye6 Carpentry 3 03-04-2009 12:09 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
