Old 05-30-2006, 06:06 PM   #1
Doing it myself
Alan's Avatar
exterior finish work
What kind of filler should one use for filling gaps in trim boards etc on the exterior of a home? Inside, I just use wood putty and/or painters caulking.
Are those acceptable for working outside too?
Old 05-30-2006, 07:31 PM   #2
Pro Painter
AAPaint's Avatar
They are if you're using quality fillers. The trick is to use it sparingly first of all, and to make sure you prime any areas you plan on filling. If the wood is soft and mushy, forget it. It needs replaced. Don't caulk gaps larger than 1/4". Anything larger needs a backer, and I'd recommend vulcum for those areas. I use 1100A siliconized latex from SW that has a 55 year warranty. For wood fillers, there are many choices...the important part is that you prime, fill, and prime again. If you don't protect the filler or the filled areas, and give it something to stick to it will fail. Also, filling nail holes is a whole different story from filling large holes on rotten wood.
If you're talking rotten wood though, you really should replace it, find the source of the rot and remedy it while the wood is removed. Back prime anything you replace by priming the entire piece of wood, front-back-end grain.
Hope that helps.
AAPaint is offline   Reply With Quote
Old 05-30-2006, 07:59 PM   #3
Doing it myself
Alan's Avatar
Definitely not rotten. Fresh boards, primed and painted twice on all 6 sides. Nailed them up around the window, and due to the shape of vinyl windows, and minor imperfections, they don't fit snugly against the edge of the window.
Old 05-31-2006, 04:15 PM   #4
Pro Painter
AAPaint's Avatar
Oh, that's typical. Just caulk using a quality siliconized latex. If the gap is over 1/4" cut a slice of backer rod to fit and then caulk. Any quality wood filler or exterior spackle will work fine for the nail holes.
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 09:44 AM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
is this bad tiling work? garrick Flooring 17 09-27-2006 01:30 AM
