Exterior Entrance Door - Painting - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 05:40 PM   #1
exterior entrance door
entrance door is stained & sealed w/polyurethane. I would like to paint over it. Anyway to do it without stripping to bare wood?
Thanks a lot, Robert
robert34 is offline   Reply With Quote
Old 11-20-2011, 09:05 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
If the poly is in good shape, you might get away with a scuff pad for a good bonding surface.
Old 11-21-2011, 04:40 AM   #3
I would give it a good sanding and apply a quality bonding primer, then apply two coats of a quality finish. Zinsser makes a number of bonding primers which you can get at the big boxes.
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
Rotten bottom plate and subfloor around exterior door deraj123 Building & Construction 5 08-13-2010 10:43 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
1950s Bedroom Door Lock DeeJaye6 Carpentry 3 03-04-2009 12:09 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
