Exterior Cinder Block Walls - Painting - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 04:00 PM   #1
exterior cinder block walls
My homes exterior is cinder block and it has been painted and the old paint is flaking off. I need to know the best diy way to cover these walls! What type of paint or stucco or whatever other finishes! I had thought about using the garage floor paint with epoxy. Open to any suggestions!
Bridgette is offline   Reply With Quote
Old 01-09-2011, 05:31 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
I would use Sherwin Williams Shercrete. It is for interior-exterior masonry surfaces. It comes in any color, does not need primer, is breathable, flexible and is also a waterprofer. Apply two coats. You can click on our concrete pool deck coatings here http://www.kelloggspainting.com/Concrete-Coatings.html to learn more about Shercrete.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
Bridgette (01-09-2011)
Old 01-09-2011, 08:52 PM   #3
Rewards Points: 252
You could also look into a product called Thorocoat - or even better IMO - is thorolastic. Depending on where you are located may not be the easiest product to find, but they are great elastomeric coatings for exterior surfaces. Pretty easy to apply..
good luck!
mazzonetv is offline   Reply With Quote
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
basement block walls twrozz Building & Construction 1 06-25-2010 02:49 PM
block walls twrozz Building & Construction 0 06-24-2010 10:26 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 09:35 AM
