Ext Paint For Interior Application? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 11:16 AM   #16
BUT can you use OIL based primer and use LATEX paint over it without problems?
Thanks!
PaoloM is offline   Reply With Quote
Old 10-22-2008, 05:33 AM   #17
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
YES.
Old 04-16-2009, 08:50 AM   #18
I have yet to paint this cabin as I've had no time but I plan to in the next month or so. I've done a little research and all I can come up with is exterior paint for the walls would be the best route BUT I'm concerned about chemicals that exterior paint may have that interior paint does not? Is it safe for interiors? If I go with exterior paint on walls do I use oil or latex primer? The last thing I want is for the walls to flake.
Paolo
Old 04-17-2009, 04:21 AM   #19
chrisn's Avatar
Rewards Points: 496
As has already been posted
Do Not Use Exterior Paint on the Interior
I do not know why you still feel the need to do this,you options have alresdy been explained.
Old 04-17-2009, 07:29 AM   #20
I meant that in regards to a SAFE exterior paint IF there was such a thing.
I will most likely go with an Oil Primer and just use regular latex inerior paint.
This might be a dumb question but does the paint finish (glossy, semi, etc.) have any effect on the elasticity of the paint?
I really appreciate all the help this forum has given!
Old 04-17-2009, 07:53 AM   #21
the Musigician
DangerMouse's Avatar
chris knows his paint....
as to your floor problem, do whatever to the floor and simply use area rugs scattered. they can be taken out and beaten or shaken, and you can take them with you for cleaning in between seasons of use.
DM
Old 04-18-2009, 04:54 AM   #22
chrisn's Avatar
Rewards Points: 496
SAFE is all relative, it is just that no paint co will recommend any of their exterior products on the interior, they MUST know something!
Old 04-20-2009, 10:10 AM   #23
Thanks Chris ... Oil Primer and latex finish is the answer. For the floors can I do the same or is there something else you would recommend?
Old 04-20-2009, 10:56 AM   #24
Matthewt1970's Avatar
Rewards Points: 1,098
Glossy is a little less flexible, but the difference is small. And yes, use interior paint for the inside, and exterior paint for the outside. Exterior paint will not last longer than interior paint on an interior application.
Old 04-21-2009, 04:30 AM   #25
chrisn's Avatar
Rewards Points: 496
Oil prime and
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
