Experiencing Problems After Wallpaper Removal - Painting - DIY Chatroom Home Improvement Forum
Old 09-06-2008, 11:37 AM   #1
experiencing problems after wallpaper removal
Hi everyone, first post here and I wanted to say thanks ahead of time for any input. Here is my problem and its details:
I am working with plaster walls after stripping wallpaper. The walls were stripped using TSP and thouroughly cleaned/rinsed afterwards. I allowed the walls to dry overnight before I applied an oil-based primer. I was told to use this over latex because it would create a barrier against any moisture left in the wall and my top coats. After priming, I sanded the walls and applied some mud to areas that needed attention using powder sheetrock (45 minute). I allowed the mud to dry 24 hours before I sanded, vacuumed and primed the patches. Since I had some laying around I used a flat white latex to prime the patches and everything looked good, no bubbles yet. I allowed the patched and primed areas another 24 hours of drying time before applying my wall color. Now when I applied the first coat of wall color (latex, eggshell) I noticed a few bubbles but they flattened out by the next day. 24 hours later when I applied the finish coat I noticed alot more bubbling and this time they did not flatten upon drying.
So now I'm not sure what I should do. Most of the bubbles are so small I am tempted to not touch it because it really isn't that noticeable from even five feet away. I am however worried about premature peeling if I leave it alone. Should I sand the bubbles down and throw another coat on?
So I guess I'm looking for a few things here...Options on where to go from here and also, What did I do wrong? Should I have primed the patchwork with something other than a flat white? Should I not have used an oil-based primer for latex paint? I was told you can use latex over an oil-based primer but not oil-based paint. Anyway, apologies for the length but I wanted to be as specific as possible. Any suggestions would be great and thanks again.
gocubs is offline   Reply With Quote
Old 09-06-2008, 04:59 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
If could be any of a number of factors
But before we get into that:
What was the exact oil primer used, and what was used as a top coat?
Are the bubbles only over the areas patched with quick mud?
When the wall covering was removed, was there paint underneath?
slickshift is offline   Reply With Quote
Wallpaper removal and lead paint risk? rhena Painting 12 06-07-2011 04:30 PM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
Wallpaper Removal [Forgot Where I Posted Before] shapeshifter Remodeling 4 01-24-2008 12:58 PM
Fixing a wallpaper removal mishap applesusan Painting 3 07-26-2006 08:02 PM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 05:41 PM
