Expanding Foam Problem - Painting - DIY Chatroom Home Improvement Forum
Old 07-28-2006, 04:09 PM   #1
expanding foam problem
ive had a bit of an accident with expanding foam.
ive had some drop down as its been drying, as soon as i noticed it i wiped it off but its all dryed on & i cant get it off (my garage door) any ideas that wont take the paint off??
please help!!
nev1 is offline   Reply With Quote
Old 07-28-2006, 08:04 PM   #2
please help!!
Try a paint scraper, It should pop right off.
didn'tdoit is offline   Reply With Quote
Old 07-29-2006, 09:21 AM   #3
Painting Contractor
A scraper should work, buy be careful. Also, I've seen a product called "Foam Eater"...do a search I dont know much about it....good luck
Paintguy26 is offline   Reply With Quote
Expanding foam insulation, where to find it in Nova Scotia? tankd0g Building & Construction 6 06-28-2010 04:33 PM
why use paint brushes instead of foam brushes? joeyboy Painting 18 09-23-2007 05:52 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing/Siding 3 07-25-2005 05:31 PM
