Emulsion Paint Dilution-water? - Painting - DIY Chatroom Home Improvement Forum
Old 05-07-2010, 11:15 AM   #1
Emulsion paint dilution-water?
I have an old tin of a really nice colour emulsion paint,but some liquid has leaked out,looks it little oily and now the paint is really thick.
What can I dilute this with?water? is there something else,better perhaps
caffeinated is offline   Reply With Quote
Old 05-07-2010, 05:17 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
You're wording leads me to believe that you are from across the pond, maybe England? Anyway, emulsion paint over there means oil based here and you would need to thin with mineral spirits or turpentine, whatever you call it there.
Old 05-07-2010, 05:36 PM   #3
Oil based
Thanks,
I thought it was a water based paint.
We in Blighty called it white spirits,turps or thinners.
Hope you are sure.
Thanx a bunch!
Old 05-08-2010, 02:52 AM   #4
chrisn's Avatar
Rewards Points: 394
It should tell you on the can.
I am NOT sure.
Old 05-08-2010, 03:23 AM   #5
Not on can
No,nothing like that is on the can,its a Crown paints product,but the stuff that leaked out looked like it had an oily appearance.
Also I think water will not work,just a hunch,but will find out soon enough!
Old 05-08-2010, 10:16 AM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
Look to see what it says to use for cleanup.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
caffeinated (05-08-2010)
Old 05-08-2010, 06:41 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
Yup, that would be the stuff for thinning
slickshift is offline   Reply With Quote
Old 05-08-2010, 08:11 PM   #8
Yes its water,as on the tin,how to clean the brushes.
Mathew got it
Old 05-09-2010, 03:10 AM   #9
chrisn's Avatar
Rewards Points: 394
Told you I was not sure
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
