Eliminate Paint "creep" Under Tape - Painting - DIY Chatroom Home Improvement Forum
Old 02-25-2014, 11:41 AM   #1
Eliminate paint "creep" under tape
This one is probably well known to professionals but was new to me when a painter told me at a paint store. If you use tape to try to get a straight border between 2 colours (like ceiling & wall; wall & trim etc.) try this - it worked great for me. Take a white (flat) ceiling and beige wall as an example. Paint the ceiling & let it overlap onto the wall - the usual 2 coats. Then run your tape around the edge of the ceiling flattening as well as you can. Now you deliberately paint a narrow strip of white on the top of the wall overlapping it onto the tape. Use lots. Let it dry completely. Now you have a seal on the wall edge of the tape. If any creep happened it will not show on the ceiling being white on white. Then do your beige covering any white paint at the top of the wall and overlap the beige onto the tape. Now you can carefully remove the tape giving a straight line (as straight as you managed to apply the tape.) The white seal prevented the beige from getting under the tape onto the ceiling. Try it. It is easiest if the last coat is the darker colour but works either way. With the tape on the wall using beige to seal the ceiling edge, it will just take multiple brushings of white to cover up the beige seal.
DIY99 is offline   Reply With Quote
The Following User Says Thank You to DIY99 For This Useful Post:
Jmayspaint (02-25-2014)
Old 02-25-2014, 11:53 AM   #2
Jmayspaint's Avatar
Rewards Points: 534
Good post. That method does work well.
Another way to seal the tape edge is with a thin smear of clear acrylic caulking. After taping run a very small bead along the edge of the tape then wipe it down smooth. This method is a little trickier and the tape needs to be pulled fairly quickly before the paint and caulk dries completely. But its useful when the surface you are taping to is not being painted, or is textured.
There are various other clear acrylic products that can be used instead of caulk.
Frog Tape sells a little bottle of edge sealer with some of there tape. That works well also, just more costly.
http://frogtape.com/index.php/produc...xtured-surface
Jmayspaint is offline   Reply With Quote
Old 02-25-2014, 12:01 PM   #3
Eliminate creep.
Thanks Jmay. Caulk sounds better for stucco ceilings My house has lots of it.
Old 02-25-2014, 06:24 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Or( easier, IMO) seal it with a small brush and Gardz
Old 02-25-2014, 07:22 PM   #5
Rewards Points: 5,974
Just read frog tape now has one for texture. A roll of tape and a bottle of sealer that seals the edge of the tape I guess.
Old 02-26-2014, 01:23 PM   #6
Painting Contractor
Rewards Points: 87
Sounds like the method would work, but would be extremely time consuming. Why not just put the extra time into painting a straight line to begin with.
kkeith is offline   Reply With Quote
Old 02-26-2014, 04:05 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
I had to show an interior decorator that trick over the summer when she was painting stripes.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 02-27-2014, 01:01 PM   #8
Rewards Points: 4,792
When we were younger, my dad would make fun of artists who did "silly" abstract paintings like this. I can appreciate it a little more now.
p.s. try the 3M Edge-Lock tapes.
p.p.s I would never try this at wall/ceiling borders - never found a need for tape there, thus no bleed through. This is really for color borders out in the "open field", e.g. painting stripes like matthew's decorator.
jeffnc is offline   Reply With Quote
Old 04-17-2014, 02:22 AM   #9
Rewards Points: 125
This is the method I use for razor sharp lines every time, even on heavy orange peel textures. Thanks for sharing!
bilug is offline   Reply With Quote
Old 04-17-2014, 07:13 AM   #10
Eliminate 1 step and when you paint the ceiling and you are going to paint the walls. Don't tape the walls, deliberately bring the ceiling paint down the wall say 1/2". Then if you tape all you have to tape is the ceiling then when you paint the walls your wall cover will go over that 1/2". Do the same for cutting this makes it so much easier because you don't have to twist your neck to cut in the ceiling. When you cut the walls again you cover the 1/2" of ceiling paint on the walls and you are looking straight ahead to do your cutting.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Xpost - Painting/Patching Tape Paint mobiledynamics Painting 5 06-25-2012 11:33 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Paint is peeling off when I lift masking tape! Help! HelloMotto Painting 10 07-15-2009 09:53 PM
