Electric Paint Sprayers - Painting - DIY Chatroom Home Improvement Forum
Old 02-19-2014, 10:00 PM   #1
Rewards Points: 87
Electric paint sprayers
Are there any electric paint sprayers that are any good? Say just for small jobs. I was thinking of getting the Wagner Flexio 590 for doing some doors, my fence, and just random small odd jobs like that.
http://www.lowes.com/pd_456606-97-05...ductId=4619636
Bennylava is offline   Reply With Quote
Old 02-20-2014, 05:11 AM   #2
Rewards Points: 5,974
Yes as long as you know their limitation they are ok. I had one I used to use for like I had 1 door to paint. I would take the door off take it outside and spray it. One thing I learned with it, don't let it get over half empty, if you do it would tend to spit.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (02-20-2014)
Old 02-20-2014, 06:28 AM   #3
Gymschu's Avatar
Rewards Points: 820
They're ok. I use my old Wagner to paint stuff like wicker furniture, etc. I'm sure it would be fine on some doors and fencing. Just don't go in with high expectations.
Gymschu is online now   Reply With Quote
Old 02-20-2014, 10:32 AM   #4
Rewards Points: 13,694
That would drive me nuts trying to do a bigger job like that fence, having to stop every few min. to refill it.
Old 02-21-2014, 11:45 PM   #5
Rewards Points: 87
Yeah, I didn't think about that part. Maybe there is a way to rig it up to a bigger tank. Or just buy the more expensive one that rolls around on these little legs. That's probably the way to go. I think you can hook those up to a 5 bucket of paint or a 1 gallon.
I'd just like to avoid an air spray rig, they require air, and my air compressor is really small. Also to get a decent one, its really expensive. The decent electric ones seem FAR cheaper.
Old 02-22-2014, 05:57 AM   #6
For small jobs like that I've found it's faster and I use less paint just rolling it.
By the time you get it set up, get the paint thin enough, not have to deal with masking or over spray and the clean time I would have been done with a roller and brush.
Gymschu (02-22-2014)
Old 02-22-2014, 10:19 AM   #7
Gymschu's Avatar
Rewards Points: 820
You can hook up you electric sprayer directly to a paint can with a clear, long tube. I'll see if I can find a picture of one. It's the clear tube in the lower left of the picture, I think.
Old 02-22-2014, 10:40 AM   #8
MarginallyQualified
Rewards Points: 2,464
...for doing some doors, my fence, and
If the job is small enough to be done WELL with a sprayer
it's small enough to be done well with brush and roller too.
If the job is big enough to warrant spraying (like that fence)...
you can rent the proper sized spraying equipment to do it right.
In between are things like wicker furniture.
Unless you have a lot and often... spray cans will suffice.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 02-23-2014, 03:44 PM   #9
What kind of fence is it picket, solid, wood, chain link, solid panel, rail?
What is on the other side of the fence neighbor, field, garage?
How much fence is there a couple hundred feet, 1/2 mile, 2 miles?
These factors all have a bearing on best way to paint. Gotta say though it would be fun to watch the brush and roll guys do a couple miles of fence.
Old 02-23-2014, 03:48 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
I had one of those Wagners.....not worth the trouble.
If the job is too small for my airless....and too big for the brush....then my go to is a HVLP sprayer.
The Following User Says Thank You to ddawg16 For This Useful Post:
Gymschu (02-23-2014)
Old 02-23-2014, 04:31 PM   #11
Jmayspaint's Avatar
Rewards Points: 534
I got one of these little Gracos one time for 100 bucks. It worked very well for small/medium spray projects. If you have a short line (25' or less) you can spray a small project without much material waste.
I ended up using it way more than I would have thought for the two years that it survived. I could even do small Sheetrock jobs with it.
I've also used Wagners, and Graco hand held models. Of all of them, I would recommend this or something similar for smaller occasional spray jobs using acrylic paint/stain.
http://magnum.graco.com/products/M_P...ages/0MagnumX5
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
ToolSeeker (02-24-2014)
Old 02-23-2014, 06:47 PM   #12
Painting Contractor
Rewards Points: 155
I would agree that the Graco cup sprayer is a good product. It is much more user friendly than the Wagner, sprays unthinned latex, and is easy to clean up.
VAProPainter is offline   Reply With Quote
Old 02-27-2014, 12:06 PM   #13
Rewards Points: 4,796
The Wagner Flexio 590 is pretty good, I've used it with good results on small to medium projects. Some people who are referring to "the Wagner" seem to be thinking of older Wagners in general, and not aware that the Flexio sprays unthinned latex just fine.
jeffnc is offline   Reply With Quote
Old 02-27-2014, 12:11 PM   #14
Are you saying you've used the Flexio 590, and that it's not a HVLP sprayer?
Old 03-07-2014, 08:13 AM   #15
Rewards Points: 87
I'd like to bump for the answer to this question. The Flexio 590 is the one I was looking at, due to its lower price than the Graco guns.
I'd like to have the Graco, but its pretty expensive.
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 05:19 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
1st Steps in Painting? Qckrun Painting 7 12-15-2009 12:25 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
