Easiest Way To Paint/finish Baseboard/window/door Trim In Entire House? - Painting - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 03:46 PM   #1
Easiest way to paint/finish baseboard/window/door trim in entire house?
Hello, we've recently purchased our first home which needed massive renovations, and this and another forum have been invaluable in having already answered any questions I've had but I was hoping for specific insight into a problem I am now facing.
Basically, all floors in the entire house have been or are being redone, so all of the baseboard trim was removed from every room. This house was built in 1997 and while being in a very nice neighborhood, it seems they went the least expensive route on everything they could have for the interior.
So all of the baseboards and window/door trim are, afaik, MDF painted white. We were wanting to keep it white for the ease factor, and originally decided on Dover White from Sherwin Williams as our trim color. However, with the difficulty of this and everything else we need to get done, we are no longer particular about the color as long as it's white, whether Dover White, Killz or whatever.
The Problem
For Baseboards - I've tried sanding the MDF baseboards and it is extremely difficult to sand by hand and before I try a power sander I'm hoping there is an easier way, like perhaps just painting over them.
I have a piece of broken baseboard I'm using to test on that is drying in the basement now - on one section I tried just roughing it up with a fine grain sanding sponge and painting over it with Killz Latex using a painting sponge brush.
For Door/Window Trim - Before our carpet was installed, I had painted the door/window trim in 2 rooms by just going over it with SW Dover White, I knew I should have at least sanded it somewhat first but we were on a tight schedule and I didn't want to sand when the carpet was installed so I tried it and it seemed to hold well so I didn't give a second thought to it.
Now a month later, I can see it is very brittle, so I guess whatever we do for the basetrim I will have to do for the window/door trim as well. Which this makes things more complicated than just power sanding and repainting since it's a PAIN to get the door trim off and I haven't even attempted to get window trim off yet but I can only imagine.
Any advice would be greatly appreciated.
Michael-stl is offline   Reply With Quote
Old 02-25-2012, 03:59 PM   #2
Rewards Points: 12,858
So all of the baseboards and window/door trim are, afaik, MFG painted white. We were wanting to keep it white for the ease factor, and originally decided on Dover White from Sherwin Williams as our trim color. However, with the difficulty of this and everything else we need to get done, we are no longer particular about the color as long as it's white, whether Dover White, Killz or whatever.
Not going to really matter what color you paint it, it's going to take the same amount of time to paint.
The Problem
For Baseboards - I've tried sanding the baseboards and it is extremely difficult to sand by hand and before I try a power sander I'm hoping there is an easier way, like perhaps just painting over them.
Stop wasting time with a hand sander , buy a 5" Random orbital sander, Lowes has the Porta Cable brand at the right price.
80 grit paper will work fine. I can sand a 12' piece of baseboard in about 2 min., enought to give the wood some tooth.
Throw the cheap foam brush away. Buy a kit that comes with a pan, roller handle and hot dog style roller cover. Buy some extra roller covers. The covers are going to be 6" long. Just right for baseboards.
Why are you removing it? Paint it in place with a quailty sash brush. I know there's going to be people jumping all over me but when I have to paint installed trim I use my hot dog roller to go over the face of the trim then go back over it with the sash brush to fill in low spots and even it out. Just works for me to get more paint on quicker.
I use enamel paint on my trim. Far tougher paint.
I hope this helps.
Old 02-25-2012, 08:35 PM   #3
Too Short? Cut it Again!
First of all Kilz is not a suitable finish coat and it is actually not that great a primer. If you have a coat of primer or paint on the woodwork, you shouldn't have to prime but your patches and repairs although a new primer/underlay would make your finish coat go on better.
A good quality sash brush is a must for this and expect to pay $15-18 for one. 2.5 angled sash is the type I use most and usually Purdy or Wooster. If you take care of it you will have it for a long time. I actually like to keep brushes for semi-gloss and trim finishes separate from those used for primer and wall paint. I actually start the life of a brush on trim where I want as few brush marks as possible and move it to use on walls.
If you have wide trim a roller can work but I would use a fabric, not a foam one. I find it just as fast to paint trim with a brush. You will have to chase the roller with a brush anyhow. You can get 4" rollers for window and door trim. I am always skeptical of those bag-o-brushes and shrink wrapped roller pan specials.
What kind of paint were you using? Trim is typically done in a higher sheen like at least eggshell and usually semi-gloss or gloss and it sounds like you might have been using flat, satin or something if it feels brittle? Semi-gloss takes 30 days to fully cure. I liked adding Floetrol per instructions to smooth out brush marks but consider it an option.
I used to paint trim before the final coat of wall finish. It is easier to cut in walls to the trim than trying to cut in the 1/2"-1" trim edge to the wall. You shouldn't have to pull the door and window trim off.
Old 02-25-2012, 09:12 PM   #4
Gymschu's Avatar
Rewards Points: 230
Once again, Sdsester has it right. You have a huge advantage with the trim off. Now you can set up sawhorses, use a whizz roller, and backbrush with a good nylon paint brush. Easypeezylemonsqueezy. For trim I like to use SW's Proclassic waterbourne or SuperPaint Semi-gloss. I have no idea why your paint is brittle. In over 30 years of painting I've never seen latex become brittle right after application. If it was an Oil-based paint, I could understand the brittle comment. If you feel you must prime, use a good bonding primer such as Zinsser's 1-2-3. It will bond to any type of older paint and give your new topcoats something to "bite" onto.
Gymschu is online now   Reply With Quote
Old 02-25-2012, 09:41 PM   #5
Sirs
I live in alaska and, I have build a cabin by a lake, I have used green board all thru out the cabin. I am now ready to paint. Any succession on primer for moisture and a finish paint companies.
I will be going up in the winter so I will have to deal with moisture, that is why I when with green board.
tstanbro is offline   Reply With Quote
Old 02-25-2012, 09:57 PM   #6
BraniksPainting's Avatar
Originally Posted by tstanbro View Post
Sirs
Any good primer will do. In areas with high moisture, I prefer to use Sherwin Williams Loxon Masonary primer. Yes, I know you are applying it on drywall but it provides great protection. Your top coat will provide you with the moisture protection but here are some excellent choices. For finish paint, I personally would use Sherwin Williams SuperPaint.
PRIMER
(if needed)
Premium Wall & Wood Interior Latex
Loxon Concrete & Masonry
SUGGESTED FINISH
Duration Home®
Cashmere®
SuperPaint®
ProClassic®
BraniksPainting is offline   Reply With Quote
Old 02-25-2012, 10:30 PM   #7
Green board
Thanks for the info, I will go and check it out at the paint store.
Alaska
Bad Ceiling Cracks in Entire House john0kirk General DIY Discussions 3 02-09-2012 07:06 AM
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 03:38 PM
New to this -- redoing carpet/hardwoods in entire house dahlias987 Flooring 4 10-22-2010 06:51 AM
Entire Gut/Refurb on 2300 sf house... G.Lo Building & Construction 4 07-28-2010 11:33 AM
Can Durock Build an entire house? chatman General DIY Discussions 10 12-31-2006 01:35 PM
