Old Yesterday, 11:02 AM   #1
Share |
Duration exterior second coat
Do I need to apply a second coat of Duration flat if sprayed on and back rolled. Original paint is A100 on pre primed Hardiboard. It is three years old. Live in Bluffton SC.
Bobsac is offline   Reply With Quote
Old Yesterday, 11:18 AM   #2
Jmayspaint's Avatar
Not necessarily, Duration Can be a one coat system if its applied thickly enough. But unless the coating thickness was verified during application to be at least 8mil wet, then its safer to assume that a second coat would be required to have enough film build to be eligible for warranty.
Coating thickness of the dried film can be checked (and it certainly would be in the case of a warranty claim) but that requires special tools and in most cases is destructive to the coating.
Jmayspaint is offline   Reply With Quote
Old Yesterday, 03:26 PM   #3
Thanks Jmayspaint. Much appreciate your help.
Old Yesterday, 09:28 PM   #4
Painting contractor
Why not go ahead and do two coats and know it's done right? Are you just changing color or has the other paint failed after 3 years from only having one coat on the siding?
Red Dog is offline   Reply With Quote
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 01:55 PM
Sherwin Williams question... 1 coat or 2? MatP Painting 4 06-09-2012 08:52 AM
One COAT or TWO? Sarasotateve Painting 4 12-02-2011 03:38 AM
Stucco: Is it better to use 1 coat of of finish coat throughout or 3 coat system? psubaron Building & Construction 5 10-06-2011 07:48 AM
SW Duration Home interior problems marathon851 Painting 9 10-09-2007 11:04 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
