Durable Paint For Utility Room To Prevent Chipping? - Painting - DIY Chatroom Home Improvement Forum
Old 06-13-2008, 04:33 PM   #1
Durable Paint for Utility Room to prevent chipping?
I'd appreciate any suggestions on how to get the most durable finish for walls in utility room-type areas that will frequently be bumped/scraped by things like bikes, ladders, etc.
I recently painted my rear condo entrance area/foyer with Behr enamel primer and 2 coats Behr premium plus Satin Enamel latex. After about 2 months I began keeping my mountain bike in this area, and the handlebars easily chipped off parts of the paint that they were resting upon.
Should I consider repainting with additional coats to provide a thicker or more durable surface? Would 3-4 coats make a difference? Would a different type of paint or exterior paint hold up better?
The only other idea I had was to find some sort of plastic film that I could apply to the parts of the wall at risk.
Thanks in advance for any suggestions!
Painter Clouseau is offline   Reply With Quote
Old 06-13-2008, 09:52 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
If the paint is coming off, it's an adhesion issue, not a "needs more" issue
Adding more won't help
You want to scrape and sand the walls to remove any/all loosely adhering Behr
Spot prime the repair areas with a quality primer
(NOT Behr....Zinsser, Benjamin Moore, or Sherwin Williams, only)
Fill/smooth the repair areas with joint compound if needed
Sand smooth the repairs, wipe clean, and re-prime (the whole wall if appropriate)
Top coat with a quality paint from the above mentioned manufacturers
(again, no Behr)
slickshift is offline   Reply With Quote
Old 06-14-2008, 09:44 PM   #3
Thanks Slick!
I hadn't been thinking about "adhesiveness" as the critical property for the paint's durability. I suppose it isn't the strength of the latex layer itself, but whether the latex will stick to the underlying surface when it is subject to external forces that threaten to cause a tear/penetration of the latex. A paint with poor adhesion will suffer from more frequent and larger chipped areas.
I knew Behr was poor in regard to application and coverage, but this gives yet one more reason to invite Mr. Moore into my home next time!
Thanks!
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Correct secquence to paint room? dan.mass@mindspring.com Painting 1 02-04-2008 08:10 PM
Paint chipping on trim and doors. RR33 Painting 9 12-30-2007 08:26 PM
How should I paint this room? LeroyFrick Painting 8 10-30-2007 06:09 PM
Old Paint Chipping Off daveofnj Painting 5 10-06-2007 10:29 AM
