Old 02-10-2010, 10:34 PM   #1
SPB
Dull Spots
Fixed about 3 screw pops on my stairwell and pulled the poped screw out and put 1 above and 1 below and then filled with joint compound. Then I spot primed with a roller the spots with Benjermin Moore all purpose primer and feathered it out onto the existing painted wall. Then once that dried I put on one coat of what was on the wall which was an eggshell and feathered it out to about a 1 ft by 1 ft area. Then I painted the hole stairwell but went from a eggshell to a matte. Now I can see each 1 ft by 1 ft area I feathered out because these spots are duller than the wall. It has been over 2 weeks since the top coat was put on. Will putting 1 more full coat on the stairwell take these away or do i have to feather these spots out again and then put 1 more coat on the whole stairwell or do i have to prime the hole stairwell then repaint it. Hoping 1 more coat will take care of the problem. Using duration paint.
Thanks.
SPB is offline   Reply With Quote
Old 02-11-2010, 04:51 AM   #2
paper hanger and painter
chrisn's Avatar
Dull Spots
One more coat should cover it.
tiny balck spots on the living room ceiling bharathi Roofing 4 02-28-2009 02:23 AM
Soft spots on roof IJustFixedThat! Roofing 3 02-17-2009 10:10 PM
insulating tight spots rtoni Building & Construction 7 12-10-2008 10:33 AM
Help with new lawn trying to fill in bare spots golfer2b Landscaping & Lawn Care 2 07-30-2008 05:02 PM
painting over spots created by painters putty azalee Painting 4 04-05-2007 11:56 AM
