Duct Tape Residue On Porous Brick Paver Tiles - Painting - DIY Chatroom Home Improvement Forum
Old 12-27-2016, 06:48 PM   #1
Rewards Points: 1,628
Duct tape residue on porous brick paver tiles
I taped some tarp down on my brick paver deck...initially I used masking tape but they don't stay so I got some GORILLA BLACK TAPE which says it sticks to rough and uneven surface...which it DID.
During that time I did some priming, some painting, some stucco work, it rain some too.
Now comes time to take everything off, as I peeled off the Gorilla tape, it leaves a footprint.
I have so far tried mineral spirit, WD-40, charcoal lighter fluid, and GOOF OFF with no luck.
Any ideas?
miamicuse is offline   Reply With Quote
Old 12-27-2016, 07:41 PM   #2
Rewards Points: 278
Re: Duct tape residue on porous brick paver tiles
Try a pressure washer miamicuse. Being in florida, I'm sure you or a neighbor has one lying around. Lol.
I've used that gorilla tape as well and it is some good tough stuff. Only problem is it does leave residue behind.
Hope you figure out how to get it off. Let us know what worked for you. Thanks.
jmon is offline   Reply With Quote
Old 12-27-2016, 08:54 PM   #3
Rewards Points: 296
I would first try more gorilla tape to see if new tape will pick up the residue from the old. I find aluminum HVAC tape works very well for this too.
ChuckF. is offline   Reply With Quote
The Following User Says Thank You to ChuckF. For This Useful Post:
Gymschu (12-28-2016)
Old 12-27-2016, 09:54 PM   #4
Rewards Points: 2,034
ChuckF has the best way that I have found.
Wrap a piece of the original tape (new) around your fingers with the adhesive out, then gradually dab the residue with this wrapped fingers, the residue will pill up and stick to the tape.
After a few pills are on your tape, turn it around to a clean side, dab more, and continue with new tape after you have removed all your taped fingers will hold.
Repeat , repeat, as many times as it takes.
Sometimes a tedious chore, but it works well.
ED
de-nagorg is offline   Reply With Quote
Nashua WaterProofing Repair Tape for Insulated Air Duct? justplumducky HVAC 3 05-02-2016 09:43 AM
Duct tape Ok to protect new Americast tub? ghutch Remodeling 0 10-21-2013 05:28 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
brick paver patio fishin dude Landscaping & Lawn Care 7 03-03-2010 11:10 PM
how to remove mortar glue residue on slate tiles aggiejess7 Flooring 5 05-13-2009 04:00 PM
