Drywallers Scored The Board - Painting - DIY Chatroom Home Improvement Forum
Old 07-05-2011, 06:55 PM   #1
drywallers scored the board
Recently on a very humid day ,even worse inside ,I painted a room on a construction site As soon as it started drying it looked like 80 grit sandpaper all over the ceiling. Upon investigating all the rough pieces were on the board right next to where the taper had sanded his compound.I looked at a couple of small sections which had been unpainted and could see the paper on the board had been scratched and opened up
To me the only solution.would be for the tapers to skim the rough spots
Sanding of the rough spots and repainting did not leave an acceptable finish IMO The tapers blamed it on me...lol They said it was because I had sprayed it (even though I backrolled the primer)
I told them they need to go to a higher grit ,thats what they did on an airport I worked on when it was humid I was only a worker there and cant get any info from that job
Any technical info on this issue would be appreciated
torpainter is offline   Reply With Quote
Old 07-05-2011, 10:25 PM   #2
Workaholic's Avatar
Got a pic?
Sean
Workaholic is offline   Reply With Quote
Old 07-05-2011, 11:27 PM   #3
no pics but I know there is info on this somewhere ,just trying to find it This ceiling is too high to see the rough texture but I am sure this issue is going to happen again and I am just trying to prepare for the discussion that I know will happen.Worse comes to worse I'll get some N.A.C E peeps in to look at it
Old 07-06-2011, 07:27 AM   #4
Rewards Points: 256
I used to follow a drywall contractor who admitted it was the sanders fault and that his sanders were instructed and told not to sand beyond the mud line and not to touch the drywall paper. It's not the painter's responsibility to educate the drywall people.
What does the builder have to say about it?
Best of Luck
Steve
spraygunn is offline   Reply With Quote
How do you ground York furnance control board garryshaf HVAC 11 01-24-2010 01:06 PM
Tile over Particle Board dgun357 Tiling, ceramics, marble 2 01-16-2010 09:00 PM
rigid foam board and height ctkeebler Building & Construction 4 01-09-2010 03:42 PM
Ridge Board Support Dilemma castlerock Building & Construction 2 01-06-2009 07:57 PM
sagging roof, rotten ridge board sonoflee Roofing/Siding 6 01-29-2008 07:12 PM
