The Blue bucket has less water content in it. The main benefit is for the top/ finish coat (Final coat before sanding). It has a finer sand grain to it, so it sands to a 'smoother' less granular surface. The final coat is VERY thin, barely 1/16" in thickness. Also, less air bubbles with Blue top.
Use the green bucket for doing your 1st and 2nd coats. These shrink less than the blue top. Make sure that you add water and mix it up with a paddle and power drill to loosen it.
Okay, I was wondering why the darn thing was drying up so fast! I taped up some seams with the blue one. The areas on the walls were okay, but the ones on the ceiling are not so okay. Is there anyway I can repair the taping on the ceiling, or will the second coat with the green one do it? Should I try to pull the tape out or should I just skin coat it with the green one. Thganks
I did the next coat with the green one, and got some bubbles on the tape. I guess its because the blue one dried up to fast. Can I just cut open the bubbles and add more mud after the tape has dried? Thanks
Usually three total, but it wouldn't be unusual for a DIYer or newbie to need 4
Same with the sanding in between, pros usually don't, but others it might help
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
