Drywall Tape In Corners - Painting - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 10:52 AM   #1
Rewards Points: 2,176
drywall tape in corners
I hope this is my last question ever on walls.
While removing wallpaper I often see a tape in the very corner, which seemed to be put on the drywall before wallpapering.
If an edge is loose I've been pulling it off because I figure with all my wetting the wall down and scraping, it would eventually come off anyway.
Now for the first time I see a more noticible crack where the corners meet. (after pulling the tape off)
I have paintable caulk in a gun and I have spackle. Which is better.
Startingover is offline   Reply With Quote
Old 02-18-2013, 11:51 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
That drywall tape is meant to span the opening and should not have been removed.
It really needs to be redone ( applied with taping compound, and sanded.
Caulking the corners will probably not be enough, and just spackle or mud will fall out or re-crack.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-18-2013, 12:03 PM   #3
bj thanks.
Darn, why didn't I ask sooner?
Old 02-18-2013, 01:47 PM   #4
Rewards Points: 5,978
Don't beat yourself up to bad if it was loose it needed to come off and be redone anyway. Where are you in central Fla.?
Old 02-18-2013, 04:31 PM   #5
I'm near Orange City. Just looked at your profile. Guess where I'm from? Stow, Ohio. You're the 3rd Ohio person I've met on here.
Old 02-18-2013, 04:34 PM   #6
We charge extra for matchmaking... .lol
Old 02-18-2013, 04:46 PM   #7
LOL
Old 02-20-2013, 02:23 AM   #8
Rewards Points: 626
That tape was better if you left it alone. It was to be there to give strengthen the corner Joint so it would not crack. Now you introduced a way for it crack and keep on cracking.
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
Startingover (02-20-2013)
Old 02-20-2013, 04:14 AM   #9
Sometimes in new construction, or additions, if the drywall guy knows the job is getting paper or popcorn, they only do level 2 or 3 drywall finish. I've seen it many times, latest last year on a popcorn removal. Ba$tads.
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
Startingover (02-20-2013), ToolSeeker (02-20-2013)
painting my bedroom -- found drywall tape peeling? 19mquinn79 Painting 2 03-10-2011 07:59 AM
Drywall & Hardiebacker meet on a stud...love at first sight? (to tape or not to tape) Dyoung Building & Construction 1 04-12-2010 08:39 PM
Drywall Tape? photosbyvj Drywall & Plaster 8 09-11-2009 09:17 PM
Drywall tape sticking out vancouver Drywall & Plaster 5 09-08-2009 10:04 PM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 09:27 PM
