-   -   drywall tape in corners (http://www.diychatroom.com/f4/drywall-tape-corners-172269/)
Startingover 02-18-2013 10:52 AM
I hope this is my last question ever on walls.
While removing wallpaper I often see a tape in the very corner, which seemed to be put on the drywall before wallpapering.
If an edge is loose I've been pulling it off because I figure with all my wetting the wall down and scraping, it would eventually come off anyway.
Now for the first time I see a more noticible crack where the corners meet. (after pulling the tape off)
I have paintable caulk in a gun and I have spackle. Which is better.
Brushjockey 02-18-2013 11:51 AM
That drywall tape is meant to span the opening and should not have been removed.
It really needs to be redone ( applied with taping compound, and sanded.
Caulking the corners will probably not be enough, and just spackle or mud will fall out or re-crack.
Startingover 02-18-2013 12:03 PM
bj thanks.
Darn, why didn't I ask sooner?
ToolSeeker 02-18-2013 01:47 PM
Don't beat yourself up to bad if it was loose it needed to come off and be redone anyway. Where are you in central Fla.?
Startingover 02-18-2013 04:31 PM
I'm near Orange City. Just looked at your profile. Guess where I'm from? Stow, Ohio. You're the 3rd Ohio person I've met on here.
Brushjockey 02-18-2013 04:34 PM
We charge extra for matchmaking... .lol
Startingover 02-18-2013 04:46 PM
LOL:laughing:
Nailbags 02-20-2013 02:23 AM
That tape was better if you left it alone. It was to be there to give strengthen the corner Joint so it would not crack. Now you introduced a way for it crack and keep on cracking.
jsheridan 02-20-2013 04:14 AM
Sometimes in new construction, or additions, if the drywall guy knows the job is getting paper or popcorn, they only do level 2 or 3 drywall finish. I've seen it many times, latest last year on a popcorn removal. Ba$tads.
