Drywall Seams Question - Painting - DIY Chatroom Home Improvement Forum
Old 08-13-2013, 11:43 AM   #1
Drywall seams question
hi, I recently hung drywall in my sons new room. It was my first time doing a whole room and I know I am not a pro. It came out pretty good for a newbie. I have recently applied the 3rd coat of primer. Most of the walls look great but there is one wall in particular where you can still slightly see the drywall seam even after the 3rd coat. It is not a hump but it slightly shows through the primer. All the other walls covered up fine.
My question is: When I apply the paint to this wall, will you be able to see the seam since you can slightly see it through the primer or will the paint cover this?
Just wondering if I should go with a 4th coat before attempting to paint.
Thanks,
Jay
jaytat77 is offline   Reply With Quote
Old 08-13-2013, 11:50 AM   #2
DIY staff
Rewards Points: 7,174
After you apply ONE coat of primer---look for bad drywall taping---then fix the bad spot with more mud--sand and prime that patch--
If you can see a problem when primed--it will show up worse with the finish paint,due to the sheen of the finish paint.
By the way---one coat of primer is all that is needed---primers job is to seal the new drywall and provide a good bond for the final finish paint--
Use two coats of paint---
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (08-13-2013), Gymschu (08-13-2013), jaytat77 (08-13-2013)
Old 08-13-2013, 12:01 PM   #3
It does not appear to be a bad tape job or a mud job. The seam is flat to the wall but the compound itself still shows through the primer.
Old 08-13-2013, 01:10 PM   #4
cdaniels's Avatar
Primers are not meant to "hide" that is what the paint does.Two coats of paint and it should be fine and as Mike said one coat of primer was enough.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Old 08-13-2013, 04:50 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 616
As already stated for future reference, primers are not meant to hide stuff, one coat is all you need. The paint will do the hiding.
Old 08-13-2013, 08:00 PM   #6
Painting Contractor CT
Rewards Points: 77
Post
As it was mentioned earlier, two coats of paint should fix that problem most likely..if not, then apply a thin coat of drywall compound, spot prime the area and paint the entire wall if you have to. Good Luck!
KD PAINTING is offline   Reply With Quote
Old 08-16-2013, 10:52 PM   #7
Rewards Points: 4,796
If it is actually flat, then you are fine. What you want to do with the primer coat is seal the drywall, not cover it with opaque white. Opaqueness is the job for the finish coat, not for drywall sealer.
In your post you said you put on 3 coats of primer. I'm sure you meant 3 coats of drywall compound. There should never be a need for more than 1 coat of primer over new drywall.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
jaytat77 (09-01-2013)
Tags
drywall seam , paint , primer
Question, hanging drywall in the garage WCR Drywall & Plaster 11 01-13-2013 07:09 PM
Drywall installation question Mark Harvey Building & Construction 1 10-25-2012 06:31 PM
Ceiling Drywall question Mstrenke Drywall & Plaster 9 05-18-2012 11:09 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 03:05 PM
