Drywall Repair Gone Bad - Painting - DIY Chatroom Home Improvement Forum
Old 01-29-2013, 05:59 AM   #1
Drywall repair gone bad
I repaired a large hole in a wall then used a paint that includes primer in it to paint the whole wall. The patched area has a duller appearance than the rest of the wall. Should I go a head and prime the patched area, then repaint the patched area?
tmccasland is offline   Reply With Quote
Old 01-29-2013, 06:29 AM   #2
DIY staff
Rewards Points: 7,174
It's to late to prime----how many coats do you have???? Three are needed to get the wall patch to blend in----
Old 01-29-2013, 06:39 AM   #3
One coat so far
Old 01-29-2013, 06:43 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
flat will need another coat, anything else probably 2 more
The Following User Says Thank You to chrisn For This Useful Post:
tmccasland (01-29-2013)
Old 01-29-2013, 06:45 AM   #5
Thanks guys, should I apply three coats to the whole wall or just the patched area and fan out
Old 01-29-2013, 06:55 AM   #6
DIY staff
Add one more coat to the patch---then roll the entire wall---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ltd (01-29-2013), tmccasland (01-29-2013)
Old 02-08-2013, 12:12 PM   #7
Grants Painting's Avatar
Flashing
Yes do this. Or you can use a spray can of alkyd primer. Couple light coats. Then feather out with your wall paint that really just has a cheap thickener in it so. 2 in 1 paint is a marketing RIPOFF.
Last edited by Gary in WA; 02-09-2013 at 05:55 PM. Reason: removed link per forum rules.
Grants Painting is offline   Reply With Quote
Drywall repair REXAMUS Drywall & Plaster 7 12-21-2011 04:24 AM
Suggestions to repair drywall around recessed light OhmZoned Drywall & Plaster 10 11-19-2011 07:07 PM
Using tape on a ceiling drywall repair janralix Drywall & Plaster 8 09-22-2011 11:07 AM
Drywall Repair - Paint peeled off down to drywall TJoy Drywall & Plaster 5 06-24-2011 03:48 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
