-   -   Drywall repair gone bad (http://www.diychatroom.com/f4/drywall-repair-gone-bad-170454/)
tmccasland 01-29-2013 04:59 AM
I repaired a large hole in a wall then used a paint that includes primer in it to paint the whole wall. The patched area has a duller appearance than the rest of the wall. Should I go a head and prime the patched area, then repaint the patched area?
oh'mike 01-29-2013 05:29 AM
It's to late to prime----how many coats do you have???? Three are needed to get the wall patch to blend in----
tmccasland 01-29-2013 05:39 AM
One coat so far
chrisn 01-29-2013 05:43 AM
flat will need another coat, anything else probably 2 more
tmccasland 01-29-2013 05:45 AM
Thanks guys, should I apply three coats to the whole wall or just the patched area and fan out
oh'mike 01-29-2013 05:55 AM
Add one more coat to the patch---then roll the entire wall---
Grants Painting 02-08-2013 11:12 AM
Flashing
Yes do this. Or you can use a spray can of alkyd primer. Couple light coats. Then feather out with your wall paint that really just has a cheap thickener in it so. 2 in 1 paint is a marketing RIPOFF.
