Drywall Primer - Painting - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 10:28 PM   #1
Rewards Points: 81
Drywall Primer
Remodeling a bedroom. We sanded all of the walls and ceiling prior to starting any repair work to smooth the surface and remove paint blobs, dust, lint, etc that was in the paint when the previous owner painted. Some areas, we had to replace and piece in new drywall. Lots of joint compound work due to nails pops and taping. I primed all of the walls and ceiling with Sherwin Williams Drywall Primer to seal the new drywall and joint compound, and to seal the old paint color. We are planning to paint with a satin finish. Do I need to use a different primer on top of the SW Drywall Primer or can I paint the satin finish over the SW Drywall Primer. I plan on at least 2 coats of the satin finish.
I am almost certain that I used the same primer when we completely gutted the powder room, installed all new drywall, and topcoated with a semi-gloss. But I can't remember for sure since it's been about 4 or 5 years when I did it, and I can't remember last week.
cougar01 is offline   Reply With Quote
Old 04-02-2012, 11:41 PM   #2
Rewards Points: 13,250
It will work fine, just use flat on the ceilings.
Old 04-02-2012, 11:51 PM   #3
ltd
Rewards Points: 536
sounds like you got it covered
ltd is offline   Reply With Quote
Old 04-03-2012, 07:52 AM   #4
Rewards Points: 81
Thanks! Actually, I will use an eggshell or matte on the ceiling. We used a flat paint on other ceilings in the past, and I found that if I had to wipe the ceiling for something it would create a shiny spot on the ceiling where I wiped. Flat paint, from my experience, doesn't like to be touched.
Old 04-03-2012, 05:21 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
[quote=cougar01;890836]Thanks! Actually, I will use an eggshell or matte on the ceiling. We used a flat paint on other ceilings in the past, and I found that if I had to wipe the ceiling for something it would create a shiny spot on the ceiling where I wiped. Flat paint, from my experience, doesn't like to be touched.[/quote]
In the old days this was true, not so much anymore with QUALITY flats.
Old 04-05-2012, 08:30 PM   #6
I am thinking about using a primer in my paint for the living room to paint over paneling. I am planning on leaving the grooves as well. I need to know however, if the primer makes the paint a shade lighter? I thought I saw somewhere on here that primer makes it a shade different. Just need refresher about this. Thanks for all the help this site has been giving me and my brother. I LOVE this site. We still are plugging along, but we are making progress too.
annibelle is offline   Reply With Quote
Old 04-05-2012, 08:52 PM   #7
Hi Annibelle,
The primer will have no effect on the topcoat color. Just try to use a decent paint and it will cover great in just a couple coats.
DIYHelper is offline   Reply With Quote
Old 04-06-2012, 04:10 AM   #8
chrisn's Avatar
Rewards Points: 224
[quote=annibelle;892598]I am thinking about using a primer in my paint for the living room to paint over paneling. I am planning on leaving the grooves as well. I need to know however, if the primer makes the paint a shade lighter? I thought I saw somewhere on here that primer makes it a shade different. Just need refresher about this. Thanks for all the help this site has been giving me and my brother. I LOVE this site. We still are plugging along, but we are making progress too.[/quote]
Bad idea with paneling. Un painted paneling will need to be CLEAN, lightly sanded, cleaned again, primed with a bonding primer,( not a paint and primer in the same can type of bad deal) then do you're 2 top coats.
The Following User Says Thank You to chrisn For This Useful Post:
ltd (04-06-2012)
Old 04-06-2012, 04:26 AM   #9
oops, I didn't give enough info either...The paneling in LR has previously been primed and two coats of paints applied before. My brother and I are redoing my whole house!!! I am going with off white Gilded Endive-Valspar? It is the same color that I used previously and not that long ago. My brother hates primer and I love it. I sanded it and washed it twice. I hope this is enough prep. I have one area I have still got to use some joint compound and I will do that this a.m. Thanks for info.
I decided I want my living room back sooner, so I am not fooling with filling in the grooves. I have in the rest of the place however.
Old 04-06-2012, 06:27 PM   #10
chrisn's Avatar
Rewards Points: 224
Well in that case, WHY do you need a supposed paint and primer in one?, just plain old everyday paint that has been around for God knows how long will work.
Old 04-06-2012, 07:48 PM   #11
Oh ok thenl...LOL. Sometimes simple is best answer! I have learned so much by having to do a few things with the repairs, but there are so many things to learn about and remember. I had just wanted to paint and now I can just do it! LOL
Drywall and Cast Iron Primer Advice mobiledynamics Painting 8 12-11-2011 11:41 AM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 09:13 PM
