Old 11-03-2009, 08:06 PM   #1
Default Drywall and Paint
Okay so we recently had our landlord replace two walls in our bathroom including the entire tub unit. Anyway, he put up the new drywall and filled in the creveses and (some) of the screw holes then painted a wonderful robins egg blue. Now the paint is dripping off the ceiling and running down the walls. What is the best way to remedy this? My dad said Kilz oil based primer to seal everything and my mother wants to sand.
So if anyone has any experience in this that would be great. As you can probably tell I am new to home fix-its but I'm willing to try anything.
Tsu
tsuyako is offline   Reply With Quote
Old 11-04-2009, 06:33 AM   #2
The drywall needs to be primed
Old 11-09-2009, 01:36 PM   #3
Default fixing the landlords mistakes
You will first need to sand off the drip marks from the landlord's crappy paint job. Next, scuff sand (lightly sand) both walls to rough them up a bit. Apply a latex drywall primer. Then apply a good quality latex topcoat. The landlord probably made a couple of mistakes.
1. did not prime, new drywall should always be primed whether it's with an actual drywall primer or whether with a self priming paint
2. used a junky brand of paint (behr) hence the running and dripping problem
link removed
If you wish to advertise on this site contact an Adminstrator
Thank you
ProPainter is offline   Reply With Quote
Old 11-09-2009, 03:53 PM   #4
Thank you so much. I'm hopeing to make it a weekend project (as in this weekend...) and hopefully get it done in a day or two. So if you don't mind me asking another question, what IS a good quailty paint?
Old 11-09-2009, 04:01 PM   #5
use Benjamin Moore paints
Old 11-09-2009, 04:15 PM   #6
Default A good quality paint
Benjamin Moore paints are very good as are Sherwin Williams paints. I would suggest going with an eg-shell or satin finish, unless you plan on really scrubbing your walls down often. Then I would suggest a semi-gloss finish.
Old 11-09-2009, 06:05 PM   #7
All right I'll look into those paints. Thanks guys.
More On This Topic
Hi, this is Jon on behalf of Expert Village in this video clip we'll be priming around our windows and doors. Once our caulking has dried around the windows we are ready to put a coat of primer on. Now I'm using a good exterior primer, now you don't have... Read More »
We're back in our room and now we've got, mostly finished, drywall and a coat of primer paint and we chose this orange primer color because we're going to come over it with a caramel color. Drywall, mud, tape, sanding and a coat of primer always over... Read More »
Hi! This is John on behalf of Expert Village in this video clip I will be talking about how to cover up water stains. If you ever had water damage you might have signs of water staining on the ceiling. Now if we just paint over that with ceiling paint... Read More »
Hi I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. After your drywall has been taped and textured it's ready to cover up with paint, which is the next step. Painting is another job that a lot of homeowners... Read More »
Hi! I'm Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a quality assurance walk through around this house. What you are going to be looking at stuff in your home here is that a lot of this stuff is... Read More »
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 12:00 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 12:18 PM
Flashing NoExperience Painting 13 09-04-2008 07:56 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 01:04 AM
Ceiling paint versus wall paint billyg Painting 3 08-11-2008 02:38 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
