Drywall Mud Dry Time Before Painting - Painting - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 04:34 PM   #1
drywall mud dry time before painting
How long after the mudding is complete do you have to wait to primer the bare walls?
Primer can says 30 days. Seems excessive.
dmillar is offline   Reply With Quote
Old 01-23-2012, 04:42 PM   #2
Rewards Points: 14,312
Depends. Are you using compound out of a bucket, It takes far longer for it to dry if you are and also depends on the thickness, temperature and humity in the air.
Most often it's 24 hours. If it's dry enough to sand and not smeer, it's dry enough to prime.
Are you sure you not reading how long it takes the paint to fully cure?
They make far faster setting compounds that you mix up from a dry mix. 30, 45, min. mixes are just two of them. But you better know what your doing because you have to move really fast.
Old 01-23-2012, 05:21 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
You must be reading how long to finish over the primer- not to prime over the mud. Once mud is completely dry ( anywhere from an hour to a day depending on thickness and humidity etc) and sanded ( I hope) you can prime.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-25-2012, 12:12 AM   #4
ARC Painting's Avatar
30 days is how long it takes for cement to cure before priming, maybe that is what you read? Drywall compound you can safely prime once it is solid to the touch and not soft.
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Old 01-25-2012, 06:27 PM   #5
Faron79's Avatar
Rewards Points: 260
Many forms of actual PLASTER need 30 days or more, depending on Lime content/thickness, etc.
As the others have said...as soon as a few hours.
Next day if heavier fills involved.
>>> Make sure ALL dusts are removed first!!
Faron
Faron79 is offline   Reply With Quote
Old 01-26-2012, 12:52 PM   #6
What type of mud did you use? Regular joint compound? If so, 24 hours is the usual but if you have some thick areas you will have to wait up to 3 days. Take a piece of sand paper and go over the mud. If its dry there will just be dust but if it hasn't cured long enough it will smear onto the sand paper.
BeeTee is offline   Reply With Quote
Painting over damaged drywall... tmsurf8 Painting 4 08-19-2010 04:07 PM
Need help with painting my walls red over drywall repairs tdm71 Painting 4 08-02-2010 10:34 AM
Drying time and painting a front door gramps416 Painting 1 05-17-2010 11:01 AM
First time drywaller phospher Building & Construction 17 03-12-2009 04:41 PM
Sanding drywall after painting... argh! moneymgmt Painting 3 05-06-2008 07:25 AM
