Drywall Gouge - Painting - DIY Chatroom Home Improvement Forum
Old 03-27-2012, 10:45 PM   #1
Rewards Points: 81
Drywall Gouge
Have a few small drywall gouges that I need to seal before applying joint compound. I have on hand:
1) Sherwin Williams Drywall Primer (latex)
2) Sherwin Williams White Pigmented Shellac Primer (aerosol).
3) Zinnser 123 Primer Sealer (water based).
Can I use either to seal the gouge, or do I need to buy yet another product? The drywall is torn down to the brown paper. It's only a very small area, and I was thinking that the Shellac Primer might work. The last thing I need is 1 gallon of SW Drywall Conditioner.
cougar01 is offline   Reply With Quote
Old 03-28-2012, 12:14 AM   #2
Rewards Points: 12,868
Any of them will work.
Old 03-28-2012, 11:16 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
If it's just a small area then the spray can is fine. Zinsser coverstain will also come in a spray can.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 03-28-2012, 11:26 AM   #4
Rubbin walls since'79
Brushjockey's Avatar
What you are doing is basically waterproofing the brown paper so it doesn't bubble from the mud. Of your choices the shellac will do that the best.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
Gymschu (03-29-2012), user1007 (03-28-2012)
Old 03-28-2012, 10:47 PM   #5
Rewards Points: 81
Thanks!
Old 03-29-2012, 06:15 AM   #6
No they won't. You can't put a latex primer over brown drywall paper. It will not stop moisture from the joint compound from penetrating so it could cause an air pocket under the patch and it will fail. I'm not familiar with Gard, which is latex, but I get the impression that it would work. But, of the choices offered, BIN is the only choice. But for me, that's a cover stain job, as Matthew hinted to. Joecaption, there's what, thirty other forums here, all of which I'm sure your expertly suited for. I think you're more valuable there.
Old 03-29-2012, 06:10 PM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 140
[quote=joecaption;887020]Any of them will work.[/quote]
What's you're definition of work?
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 10:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
