Drywall Damage After Wallpaper Removal - Painting - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 03:29 PM   #1
Hi there!
I'm new to the forum and would really appreciate any help you can give.
I'm in the process of removing wallpaper from what I suspect was put up on unsealed drywall. The removal is taking off pieces of the drywall paper and in some places you can see the brown board of the drywall. Also, I'm using one of the round scoring tools and think I've used too much pressure so have probably damaged the drywall that way too.
Ultimately I would like to have a knockdown texture on the walls with paint. Here is my plan:
(1) Seal the drywall with Gardz Dry Wall Repair so it won't bubble up.
(2) Where the damage is deep, repair with drywall compound and sand.
(3) Texture over the repaired drywall.
(4) Prime
(5) Paint
A few questions:
(1) Do I need to seal over the texture as well?
(2) Do I need to worry about repairing the drywall damage (it's not very deep) given that I'm texturing the walls anyhow?
(3) Should I just skim the whole wall rather than repair specific sections? If so, do I texture right on top of the skimming?
I'm sure I'll come up with more questions, but thank you in advance for your help!
katega is offline   Reply With Quote
Old 01-26-2012, 03:41 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Basically good plan. It depends on how deep the damage and how light the texture. I don't do much wall texture- i'm from the smooth wall part of the country- but generally I would think to get a basic smooth and sound wall first would be the way to go.
Pre fill any deep stuff, and if there is a significant amount of digs an overall skim is a good idea.
What kind of texture? spray knock down, skip trowel?
And after texture- depending on the finish priming is always a good idea- makes for a better finish.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-26-2012, 03:51 PM   #3
Thanks for the answer!
For the texture -- I'm trying to match a knockdown texture on the ceiling that was sprayed on, but I don't want to use a sprayer, seems like too much trouble and I've never used one. So I've seen instructions on how to roll it on with a high-knap roller and then do the knockdown. Any thoughts? I don't need it to be a perfect match, just generally similar.
For the end primer -- it sounds like after the texture I can just use a regular primer, it doesn't need to be a specific kind?
For the repair -- I'm thinking I can get by with spot repair rather than a whole skim. For some reason I find the idea of skimming the whole wall intimidating...
Thanks again.
Old 01-26-2012, 03:51 PM   #4
Mr. Paint's Avatar
If you are using a spray texture, skim the walls after the repairs to make an even surface before texturing. The entire wall will need primed with a PVA type sealer (Including texture) and then paainted.
If you do not want to skim the whole wall and just do patches, you will need a porosity control primer such as Hamilton Prep-Coat before you texture.Here is a site with helpful answers:
http://www.hamiltonnw.com/TechBulletins.asp
Mr. Paint is offline   Reply With Quote
Old 01-26-2012, 04:20 PM   #5
Katega will already have gardz ( according to plan) , and that would also work to even porosity.
Old 01-26-2012, 04:26 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 470
really?
Old 01-26-2012, 04:30 PM   #7
So when exactly should I apply the Guardz? Just over the bare drywall before I patch it? Just after I patch and texture the drywall? Or do it twice pre-patching and post texture?
Thanks! I'm feeling more confident to do this myself rather than hiring someone...
Old 01-26-2012, 04:49 PM   #8
Originally Posted by you will need a porosity control primer such as Hamilton Prep-Coat before you texture.Here is a site with helpful answers:
[URL
http://www.hamiltonnw.com/TechBulletins.asp[/URL]
Hamilton looks like it has some great products for this, but I can't find them anywhere, do you have any suggestions?
Old 01-26-2012, 05:06 PM   #9
yes. use the Gardz
Use it after stripping to seal the damage- use after all repairs to even porosity before texture.
It is clear and thin- so be careful- but it works like a dream.
Old 01-26-2012, 05:38 PM   #10
Mr. Paint's Avatar
Katega:
I agree with Brush Jockey on the Gardz. I sold over 200 gallons for a local Hyatt Hotel near SFO Airport when they stripped off the vinyl that was applied to unsealed walls. Gardz was applied first, then damage repairs, and a final coat of Gardz to seal it all.
Hamilton may be out West more. I don't know where you are. USG products seem to be sold nationally.
Old 01-26-2012, 10:21 PM   #11
That's a good point BJ, prefill. You can't fill deep gouges and skim coat at the same time. Applying finer coats of spackle requires the surface to be relatively uniform.
Tags
drywall , texture , wallpaper
Best Tools for Drywall Removal? neo95gt Drywall & Plaster 59 12-27-2011 12:44 PM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Wallpaper paste removal oscarMadison Painting 3 04-18-2009 10:25 AM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 12:13 AM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 05:41 PM
