Drying / Recoat Time - Painting - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 10:28 AM   #1
Drying / recoat time
Does everyone wait the full 4 hr drying time typical latex paint lists? I have painted well before that many times without any problems or paint failure.
beerdog is offline   Reply With Quote
Old 04-03-2011, 10:43 AM   #2
Yes and no. If you're pressed for time and not using a semi gloss or higher sheen, the color isn't a deep base and it's dry to the touch you should be all right. In that ase 4 hours is a very long dry time. I like to let deep colors cure over night as they take longer to dry due to the amount of colorant. Probably overkill but that's my preferance.
kboyz is offline   Reply With Quote
Old 04-03-2011, 11:39 AM   #3
interesting. Why woudl semi-gloss or higher make a difference?
Old 04-03-2011, 11:42 AM   #4
Rubbin walls since'79
Brushjockey's Avatar
Some paints need to dry through, just not on the surface , to perform right.
If you add a coat before this happens, you seal in the moisture that is trying to escape.
One trick I use all the time on something that I want to move forward faster than the can says, is put a fan on it after it has settled down. This can cut the dry time significantly.
Brushjockey is offline   Reply With Quote
Old 04-03-2011, 01:16 PM   #5
Gymschu's Avatar
Rewards Points: 184
That's what I do Brushjockey, especially if pressed for time.......a fan does wonders although the downside is you sometimes blow dust and debris onto the paint film.
If I have plenty of time, I actually like to wait a day for the first coat to dry then hit it the next day with coat #2. That doesn't happen too often.
Old 04-03-2011, 03:20 PM   #6
P Marage's Avatar
Rewards Points: 87
Sometimes if not cured quite enough it tends to soften the previous coat and not usually but sometimes it will soften it enough to pull the previous coat of paint away before its bonded. Flat and eggshell have less latex or more chalky sub-straits(or vice versa, im not sure) leaving it more porous allowing moisture to escape easier, drying faster.
You might find that when cutting in to early your brush feels tacky and pulls a bit harder across the first cut/roll making it difficult to get a nice strait cut. Acrylic is bad for this.
I may be wrong but thats my observation.
P Marage is offline   Reply With Quote
Old 04-03-2011, 03:53 PM   #7
ltd
Rewards Points: 536
i use to rush dry times and never had a problem.then again i use to do in a lot of things .maybe i was just lucky .like others have said deep colors ,small rooms like bath rooms that will have steaming showers on i go by the book , maybe even more. i use fans dayley to help dry paint i dont put it directly on wall but just to get air moving. if your a weekend warrior just go by the book ,you cant go wrong. with that said if can says recoat in 4 hours and you do it in 3 1/2 hours will life change as we know it
ltd is offline   Reply With Quote
Old 04-03-2011, 04:05 PM   #8
the Musigician
DangerMouse's Avatar
The DB acrylic semi-gloss I've been using is super fast drying too. Almost to the point of being TOO fast drying to allow a few minutes to look and find all the runs/drips/etc. (which I rarely see or do anyway, but....) It's weird to have it feel dry to the touch in 5 or 10 minutes, you know?
DM
Old 04-11-2011, 10:41 PM   #9
NACE Coating Inspector
mustangmike3789's Avatar
you should wait on your recoat window depending on ambient temp,surface temp and realitive humidity which could change that minimum recoat time by several hours. water base paints are not as critical as epoxies or polyurethane paints which need time to gas out as they cure. gassing is not really a big issue with water base paints. as someone mentioned, you could start pulling away the first coat before it has time to bite and you could also run into the first coat shrinking at a different rate than the second coat and they will not properly bond to each other.
mustangmike3789 is offline   Reply With Quote
Becoming a licensed plumber/electrician amakarevic General DIY Discussions 14 09-26-2010 10:58 AM
Cycle time Yoyizit HVAC 2 06-29-2009 08:10 PM
Can I grout a little at a time? yummy mummy Tiling, ceramics, marble 5 06-16-2009 02:21 PM
DIY tiling first time? SeraSmith General DIY Discussions 8 04-04-2009 02:19 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
