Drying Pressure Treated Wood - Painting - DIY Chatroom Home Improvement Forum
Old 10-13-2011, 11:27 AM   #1
Drying pressure treated wood
All roads lead to giving pressure treated wood 2 to 3 months average time to "dry" before considering staining (or whenever the water droplet test passes). My client is suggesting stacking the new lumber under his carport to dry. I'm concerned that not being installed, it may tend to warp and/or cup during this time. Thoughts???
Thanks,
David
Oh yeah, the wood is 2 x 6 x 12's.
Cooltools is offline   Reply With Quote
Old 10-13-2011, 11:52 AM   #2
Rewards Points: 526
It depends somewhat on the species of wood that was treated, but generally yes, it is a mistake to let it dry uninstalled. You may not have to wait 2 to 3 months either before you coat it - you only need to wait until it is dry. I think the 'longer the better' approach is an anachronism left over from the CCA days whereas the new wisdom with ACQ is to coat it as soon as the moisture content of the wood permits. My experience bears this out also.
Staining "PT" wood
Windows is offline   Reply With Quote
The Following User Says Thank You to Windows For This Useful Post:
Cooltools (10-14-2011)
Old 10-13-2011, 12:12 PM   #3
A Little Of Everything
Rewards Points: 1,362
Thanks,
David
As soon as that wood is broken out of the shipping pallet it starts to warp. He will not like the results if he just stacks it in his carport to let it dry.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
Old 10-13-2011, 03:44 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
It will also start to cup, warp, and crack if left un sealed for to long. The elements, especially the son put a beating on wood that is left un stained for long periods. It really does not have to dry out for that long of a period, unless you are staining both sides, both ends and edges, which I doubt. The sooner wood gets stained the better it will hold up and less it will cost down the road to repair.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
Old 10-13-2011, 04:24 PM   #5
kwikfishron's Avatar
Rewards Points: 90
I agree storing it is a mistake.
Use KDAT and you can paint or stain without waiting.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 10-14-2011, 10:46 AM   #6
PT Wood
Thanks for all the responses, now I won't end up with a carport full of bannana wood!
Tags
decks , pressure treated wood , staining new wood
Painting Pressure Treated Wood stephen44 Painting 14 05-14-2016 09:22 AM
Regular latex paint on treated lumber zrooster99 Carpentry 3 07-06-2011 02:43 PM
how to treat exterior pressure treated wood handrail dthome4433@comc Painting 1 04-13-2010 07:42 PM
use of pressure treated wood in the garden bscout Landscaping & Lawn Care 7 06-07-2007 12:23 AM
