Dry Wall Prep? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 08:29 PM   #16
Rubbin walls since'79
Brushjockey's Avatar
Personally I don't get the water wipe at all. Use a vacuum, a swiffer dust mop, a broom. I have never used water to clean a raw wall. Sounds like asking for trouble and a very inefficient way to get it ready.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 04-02-2013, 08:44 PM   #17
I don't really get it either, the only time I wash walls is after I remove paper. I'm just trying to steer the bullet to the fleshy part of his foot, lol.
Old 04-03-2013, 01:49 AM   #18
Too Short? Cut it Again!
Unless I read something wrong. This is not new drywall. It is has been sitting, in a garage and turning color because nothing was applied to it when it was new drywall---12 years ago. From the original post:
"The dry wall has been sitting like this for 12 years now." is what I read in the original post.
I am not suggesting to soak it with TSP but stuff like primer and paint is not going to stick to it now without some attention to trying to clean it? Unless the car, truck, boat, lawnmower, weed wacker, snow blower, etc. was always moved outside before starting? I am sorry but just vacuuming it or hitting it with a damp sponge is not going to end well in this situation. IMO.
Two coats of primer is not going to help an uncoated, decade-old piece or two of drywall in a garage on its own either?
Old 04-03-2013, 03:20 AM   #19
paper hanger and painter
chrisn's Avatar
Rewards Points: 464
Why not?
Old 04-03-2013, 03:40 AM   #20
Originally Posted by chrisn View Post
Why not?
First coat of primer needs a clean surface. Second one on top of it over something not prepped will not help. I am just saying you cannot treat a piece of 12-year old drywall, never protected in the first place, like you would new drywall. Am I wrong?
Old 04-03-2013, 06:41 AM   #21
Wetting drywall and mud ( what I should have said was raw, not new) will not clean it.
Give it a try.
if the dirt had absorbed into it, they are so porous no light washing will do anything . I would give it a light sand- finish the mudding and do exactly what the op is doing- 2 coats ( overnight dry) of 123 PLUS ( WB oil). If excessive stains bled through the first, might change to oil for the second coat.
With waterborne stain killers, often you let them bleed into a first coat which then locks them, second will finish them off. Not true for all stains, but i have had reasonable luck with Smart Prime ( aka 123 plus). If you have smaller select areas of bleed through, I would spot hit them with BIN and then do the second coat. I don't love massive amounts of solvents...
Old 04-03-2013, 09:58 AM   #22
retfr8flyr's Avatar
Thanks for all the suggestions guys. I think I am going to do what I planned. The damp sponge mop is not to really clean the walls, I know nothing will clean the paper of drywall, it's just to help take off all the accumulated dust from the sanding and years of being there. Hopefully everything will come out OK.
Earl
retfr8flyr is offline   Reply With Quote
Old 04-03-2013, 04:55 PM   #23
chrisn's Avatar
Rewards Points: 464
nope, I just miss interpreted
How to add temporary support to this wall (to open up this wall)? jsunsun Building & Construction 7 01-20-2013 09:36 PM
Creating doorways/supporting wall issues NWVintage Remodeling 2 12-19-2012 03:19 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Wall prep question medicdave Painting 9 06-16-2008 07:42 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
