Dry Lock Over Painted Block - Painting - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 10:07 PM   #1
dry lock over painted block
Basement walls were dry locked (1 heavy coat) 15 years ago and painted over w/a latex paint. Paint has since bubbled and peeled in some spots. Can walls be cleaned and dry locked again and if so what would the procedure be? If not, how would we fix?
dmel156882 is offline   Reply With Quote
Old 08-28-2011, 06:55 AM   #2
Hi Dmel, welcome to the forum. Unfortunately, drylock will not seal painted masonry. It works by penetrating into the pores. However, you can try scraping the loose peeling paint and giving the exposed areas a vigorous wire brushing, maybe even by machine. Reapply some Drylock to see if that helps. I don't know if it will, but at this point there really isn't anything that I know of to solve the problem, short of excavating the foundation and waterproofing from the exterior. I don't know the lay of your home, but be sure that you're doing everything you can to divert water runoff via your gutters and downspouts. Good Luck.
Joe
Old 08-28-2011, 04:59 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 316
sandblasting?
Troweled finish over painted block over60pirate General DIY Discussions 1 10-12-2010 02:38 PM
Drywall mud on old painted block wall? urborn2die Drywall & Plaster 2 09-17-2010 08:54 PM
Stone veneer over painted block Daystepper Building & Construction 0 09-16-2010 04:03 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
putting stone vaneer on painted cinder block dlmont75 Carpentry 2 06-28-2009 08:04 PM
