Driveway Paint Wont "stick" - Painting - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 08:05 PM   #1
Driveway paint wont "stick"
Am repainting my girlfriends concrete driveway.
There was some unknown paint on there when she bought the home. She hired a contractor to repaint it but, after parking the car on it, some spots lifted revealing the orgiinal unknown paint. Surprise...the contractor wont come back to fix it.
SO...i attempted to redo it, thoroughly washing with Formula 88 degreaser/soap. No surprise, my paint is lifting off too.
Any suggestions what to do now?
SkateLaw is offline   Reply With Quote
Old 02-17-2010, 08:27 PM   #2
and the driveway is made of ....?
Location ?
Old 02-17-2010, 08:35 PM   #3
Driveway is concrete, located in south florida
Old 02-17-2010, 08:40 PM   #4
Well that sucks that somoene painted concrete
Stain is much better
Myself I would have stripped the old stuff off rather then paint over it
I have concrete in the basement that was painted, I'll be stripping it
I'd strip it all off
Old 02-17-2010, 09:44 PM   #5
I would get or rent a high pressure sprayer and make sure it isn't going to come up any where else, if she is adamant about keeping it . There must be some sort of oily residue on the old paint. It could be coming up from under the old paint. I am an idiot so take this with a grain of salt but I would get some paint stripper and clean off the area and start from concrete.
william duffer is offline   Reply With Quote
Old 02-20-2010, 05:24 PM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Prep is the key, I would use a solid concrete stain, such as H&C, paint won't last long in a driveway. Power wash it well using a degreaser, as mentioned make sure all the loose paint is removed, if you need to scrape the driveway to remove all loose paint, make sure you degrease any oil, gas, or grease spots, repair any cracks or deteriorated concrete, Then apply solid concrete stain and you can even apply a clear sealer over the stain.
housepaintingny is offline   Reply With Quote
Old 02-21-2010, 10:50 AM   #7
Sprayboy-services.com
You are fighting a losing battle putting paint on a driveway. I would defineitly go with stain. Paint just can't stand up to the weight and friction of repeated vehicles.
Sprayboy is offline   Reply With Quote
Old 03-01-2010, 09:32 PM   #8
Paint will come off with the heat of the tires. Your best bet is to stain it with either an acid based stain or water based transparent stain and then seal over that with an acrylic sealer. I'd hire someone to do it or spend a lot of time researching about how to.
If you have information to assist someone then post it here
Advising people to cotact you thru your web-site is viewed as advertisment & is not allowed
Last edited by Scuba_Dave; 03-01-2010 at 09:41 PM. Reason: removed advertising links
PaverProtector is offline   Reply With Quote
Old 03-01-2010, 09:46 PM   #9
I have never heard of a Aid stain that will work over a previously painted surface. I also believe a s/t would have to be a fresh concrete application. Acrylics don't do the job on hot tire pick up period! and Silicone acrylic is the best, but you cannot apply it over paint. Just plain bad all over, never paint your garage floor!!!
PaintinNC is offline   Reply With Quote
Old 03-01-2010, 09:51 PM   #10
Yes, you would certainly have to strip the old paint first.
Tags
driveway paint
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
