Doors Stick After Recent Paint - Painting - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 03:01 AM   #1
Rewards Points: 518
Doors stick after recent paint
Two months ago I painted my doors and door frames with a Sherwin Williams semi-gloss latex non-tinted white, using their new SuperPaint line. It's been two months and a couple of my doors still stick really bad. No paint is transferring between the jambs and the doors but it's enough to make an audible noise and require some elbow grease to actually open the doors. Any suggestions on how to correct this?
n0c7 is offline   Reply With Quote
Old 04-25-2010, 05:11 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Wd-40
Old 04-25-2010, 11:47 AM   #3
Registered User
Rewards Points: 5,236
If they are contacting at the lock side near the top where it was close before painting because of door sag due to improper installation, install one 2" screw color to match the shorter ones in the top hinge. H.D. carries them. This will set the reveal (gap) back where it should be. If the lockset is hard to turn after it engages, bend the strike tab towards the open door some to give more room when the door is contacting the stop perimeter while closed.
Be safe, Gary
Old 04-27-2010, 07:42 PM   #4
Rewards Points: 518
Where should I put the WD-40 and will it remove or interfere with the paint?
Old 04-28-2010, 04:54 AM   #5
chrisn's Avatar
Rewards Points: 234
Just lightly spray it on where it is sticking. It will not hurt the paint after drying.I would first check out GBR's instructions, if the doors are not aligned right.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
What to do w/ old doors with 8 layers of paint on them? CoconutPete Remodeling 11 01-29-2010 02:52 PM
Best way to paint preprimed doors? bobmg Painting 3 01-18-2010 06:31 PM
