Doors - Painting - DIY Chatroom Home Improvement Forum
Old 12-03-2013, 05:27 PM   #1
Rewards Points: 2,072
doors
LOL, reading a novel one sentence made me question my painting. The sentence was about someone who was annoyed that a painter didn't paint the top of a door.
I've painted many doors in this house. Never once did it occur to me to paint the very top. (nor did I paint the bottom)
Is that something a professional would do?
Startingover is offline   Reply With Quote
Old 12-03-2013, 05:33 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
some do, some don't, me? no, unless you can see it from above somewhere
The Following User Says Thank You to chrisn For This Useful Post:
Startingover (12-03-2013)
Old 12-03-2013, 05:36 PM   #3
Gymschu's Avatar
Rewards Points: 462
It IS something a pro should do. Do we do it all the time? No. It is best to have all sides sealed up against any possible moisture that may make the doors swell and rub/stick to the jambs. I always do it with new doors but if it is older doors that WEREN'T originally done on all six sides and there's no signs of problems, I don't bother painting the top or bottom.
The Following 3 Users Say Thank You to Gymschu For This Useful Post:
joecaption (12-03-2013), Startingover (12-03-2013), ToolSeeker (12-03-2013)
Old 12-03-2013, 06:03 PM   #4
Rewards Points: 13,260
Wonder why doors stick with the change of seasons that's the reason, no one took the time to do it right and seal all sides of the whole door.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
Gymschu (12-03-2013), spraygunn (12-04-2013), Startingover (12-03-2013)
Old 12-03-2013, 09:54 PM   #5
Davejss's Avatar
Rewards Points: 740
All six sides need to be sealed.
Davejss is offline   Reply With Quote
The Following 2 Users Say Thank You to Davejss For This Useful Post:
spraygunn (12-04-2013), Startingover (12-04-2013)
Old 12-03-2013, 10:35 PM   #6
Rewards Points: 5,974
If the doors are off I do it, If they are still hung I do the top.
Old 12-04-2013, 09:15 AM   #7
Rewards Points: 256
Even the cookie cutters we did, we sealed the tops and bottoms. One builder I worked for even sent out letters from the door manufacturer stating they would not honor the warranty of any door unless all six sides were sealed and that if not sealed and the door warped, I would then be responsible for replacing it. Why argue, it made us look good to the customer. Another builder said he wanted me to remove the hinges and seal behind them. Well, needless to say, that didn’t happen.
The time spent and the benefits of sealing all six sides far out weigh any future arguments from either the owner or general contractor trying to explain why I didn’t take the time to do it.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
The Following 3 Users Say Thank You to spraygunn For This Useful Post:
Gymschu (12-05-2013), Startingover (12-04-2013), ToolSeeker (12-04-2013)
Old 12-04-2013, 02:30 PM   #8
Rewards Points: 274
I think it should be painted professionally if a person is doing something it means that work should be completed
alexjoe is offline   Reply With Quote
The Following User Says Thank You to alexjoe For This Useful Post:
Old 12-04-2013, 03:34 PM   #9
I still have 3 doors to do so when the paint is open it won't be hard to go back and paint the tops of the other 11 doors.
Old 12-04-2013, 04:39 PM   #10
Rewards Points: 256
When sealing the tops and bottoms, it doesn’t necessarily have to be the enamel coat, it can be primer. The objective it to seal the edge not make it look pretty.
Best of Luck
Steve
The Following User Says Thank You to spraygunn For This Useful Post:
Old 12-04-2013, 10:52 PM   #11
But how many people will pay the extra cost to remove a door to see if the bottom is painted and then rehang? If there are several doors this could get expensive real quick.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Startingover (12-07-2013)
Old 12-04-2013, 11:54 PM   #12
Jmayspaint's Avatar
Rewards Points: 534
I used to have this little tool to paint the bottoms of doors while there up. It was just a thin applicator pad, basically a strip of metal with 'nap on it.
Another way to seal the bottoms is to put caulk on your finger, stick it under the door, and smear it out. Caulk seals edges/end grain well. It's just messy to do and there has to be enough clearance for your finger and a piece of newspaper or something to protect the floor.
Jmayspaint is online now   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Gymschu (12-05-2013), Startingover (12-07-2013)
Made My Own Inexpensive Wood Garage Carriage Doors iffy Project Showcase 4 03-31-2012 03:07 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
