Is Door Slab Still Paintable If Dirty? - Painting - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 09:54 PM   #1
Rewards Points: 682
Is door slab still paintable if dirty?
I have an exterior slab that has tree sap and beer mug marks on it from leaving it outside for a couple of weeks.
I'm wondering if it is ruined for painting? The outer surface is like smooth paper, great after it is primed. But if I try to clean it I'm afraid it will fall apart like paper, and if I prime it I don't think the primer will stick to the stained areas.
What do you guys think?
darsunt is offline   Reply With Quote
Old 12-17-2010, 10:09 PM   #2
jschaben
Rewards Points: 502
Hi - Don't know about the beer mug marks but I bet the tree sap will bleed through most anything you put over it. Doesn't sound like you have much to loose here anyway so I would try cleaning it with 409 or similar, get as much tree sap off as possible. Scrape, sand, alcohol, whatever it takes, just don't completely soak it with whatever you clean it with, wet a rag/towel and clean as best you can. Lightly sand the rough spots and prime with shellac. Good Luck
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
Is a door slab still paintable if the surface is dirty? darsunt Building & Construction 4 12-19-2010 05:26 AM
Dirty bowl. Very dirty. jujujulia Plumbing 1 07-10-2010 10:00 AM
Painting dirty walls SimpleJack Painting 27 02-20-2010 07:51 AM
Is there such a thing as a dirty heat exchanger? suthrnreject HVAC 8 01-19-2009 08:23 PM
