Door Paint Problems - Painting - DIY Chatroom Home Improvement Forum
Old 08-25-2008, 02:18 PM   #1
Door paint problems
I recently painted all of my interior doors and ran into some issues. I did the first few doors outside and the wind kicked up and blew some stuff onto the doors, when I took it off it bubbled the paint so I sanded the areas down that had problems.
Unfortunately, when I went to put on the next coat, you can see that the areas I sanded down are "lower" than the other areas (like when paint chips and you try to paint over it.)
How do I get around that? Do I keep putting more and more paint on, or do I use some sort of wood filler?
GodFather is offline   Reply With Quote
Old 08-25-2008, 04:06 PM   #2
Rewards Points: 2,906
I think your best bet is to sand the edges of your depression to "feather edge" them. Then, painting over those smoothed edges should provide a smooth surface that won't show that there was a depression there.
As wet paint dries and the solvents evaporate from it, the film thickness shrinks considerably. So, when a paint is wet,you often can barely discern anything showing through the paint film, but as that film dries and shrinks, then everything shows through.
Nestor_Kelebay is offline   Reply With Quote
Old 08-25-2008, 07:25 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Feather sand the edges of the "lower" areas to blend them smooth to the higher areas
slickshift is offline   Reply With Quote
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Floor Finish Problems javan Flooring 7 07-29-2008 08:26 PM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
