DOOR & TRIM PAINT - Painting - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 12:11 PM   #1
dOOR & TRIM PAINT
I have stained doors and trim. I want to paint them white. What method should I use to get the best result?
GAILVINSON@ATT. is offline   Reply With Quote
Old 09-12-2011, 11:38 PM   #2
welcome Gail, I would give the surfaces a sanding to dull any sheen with 120 paper, being sure to thoroughly remove the sanding dust. Then apply a quality bonding primer, oil or latex, your choice. I prefer oil for that job, but that's me. After that you'll notice that you probably need to do some puttying of nail holes and caulking of trim joints. After that you can apply two coats of the finish of your choice. It's a good idea for better job outcome to do a fine sanding with 220 paper after the primer and first finish coats, dusting well of course. If you need any details on any of the steps, check back. good luck
Joe
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 06:04 PM
