Does Repaint Require Primer Again? - Painting - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 04:56 PM   #1
Rewards Points: 1,062
Question
does repaint require primer again?
i had some stucco window surroundings painted enamel and used zinsser primer first. now i changed my mind about the color and wanna repaint it white but was wondering if i need to use primer again. this time there is also window sealant i want to paint. should i apply the primer only over the sealant edges or should i do the whole thing over?
thanks
Old 03-06-2012, 02:22 PM   #2
BraniksPainting's Avatar
thanks
No you don't need to prime again. Hopefully your "window sealant" is paintable. Otherwise........
BraniksPainting is offline   Reply With Quote
Old 03-06-2012, 02:37 PM   #3
it is Quad window sealant. otherwise, i want to paint it white and the sealant is also white, so who cares
Old 03-06-2012, 03:45 PM   #4
Yes I have simply painted over again in those situations.. no need to use primer again.
diychat12 is offline   Reply With Quote
The Following User Says Thank You to diychat12 For This Useful Post:
amakarevic (03-06-2012)
Old 03-06-2012, 05:21 PM   #5
You should always paint over exposed caulk, especially exterior. Caulk retains a tackiness that attracts dirt. Also, caulk that is exposed to the elements will tend to degrade quicker. Use paint to protect it as well as the substrate.
Tags
repaint
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 09:06 AM
Zinsser primer not drying kevinkk Painting 9 12-17-2009 08:56 PM
Best primer for bathroom ceiling dbldee20 Painting 11 01-06-2009 03:25 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
